Brake booster pushrod - Defender Source
Old June 4th, 2013, 07:48 PM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
While manipulating the brake master and brake booster/pedal box out of the way to replace a leaking clutch master I must have misaligned the brake booster pushrod that comes out of the booster and enters the brake master.
I will be pulling the assembly tomorrow for further investigation, but thought I'd throw this out to any advice.
Is this pushrod and retaining cup servicable or will a full new booster be required?
Looks like the retaining cup got mangled slightly and slipped out of the booster.
This really sucks, because the clutch master replacement job went very smoothly and quicker than expected after reading all the trials and tribulations on this forum.
ID:	73786   Click image for larger version
brake
Brake Booster Leak jijalicious Defender Technical Discussions 3 July 3rd, 2013 04:30 PM
Rex range rover classic vacuum brake booster pedal box assy the rover shop For Sale - Parts 4 May 6th, 2013 09:16 PM
I need help with the brake booster vacuum hose routing Chip Defender Technical Discussions 0 August 30th, 2012 12:52 AM
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
