Brake Booster Leak - Defender Source
Old April 8th, 2013, 11:58 AM
jijalicious
Jiman Khosravan
'94 D90
Brake Booster Leak
Have had this problem for a few weeks now.... I know I know.. Should've taken care of this sooner...
Had the brake booster replaced a few months ago....
Braking power was different afterwards but didn't think anything of it.. but it finally became very difficult to brake.... did some research on the forum and everyone mentioned old booster and or vacuum...
So I checked for leaks and sure is... circle marks the spot... Its wet because that's how I tested it.. sprayed water on it and it bubbled...
I removed the cylinder from the booster... and reattached it... no change.
It's metal on metal... should there be a ring or seal there?
The 3 bolts that connect to the booster are pretty tight... any tighter and I risk damaging threads.
Any ideas?
~Jiman
Old April 8th, 2013, 12:22 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi, the boosters are known to crack around the mounting flange, get someone to depress the brake pedal while you watch the flange area around the bolts for movement.
btw by depress I mean push down, not tell it that its useless, overweight & it's best years are behind it.
no gaskets shown in the parts book:
http://www.retroanaconda.com/landrov...t_p581-718.pdf
regards
Gren
Old April 8th, 2013, 01:56 PM
Assuming it is like other boosters, there should be a shaft seal on the push rod, so there should not be vacuum at that flange.
http://www.corvette-restoration.com/...ic_2_large.jpg
Old July 3rd, 2013, 04:30 PM
jijalicious
Jiman Khosravan
'94 D90
So it was a little o-ring seal thingimabob...
Trevor sent me one and let me just say...I now have so much breaking power I don't know what to do with it!
~Jiman
boost, brake
Rex range rover classic vacuum brake booster pedal box assy the rover shop For Sale - Parts 4 May 6th, 2013 09:16 PM
I need help with the brake booster vacuum hose routing Chip Defender Technical Discussions 0 August 30th, 2012 12:52 AM
Transfer case leak - through trans brake drum nathanwind Defender Technical Discussions 29 July 17th, 2012 05:07 PM
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
