brake booster? - Defender Source
Old October 2nd, 2009, 09:25 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
brake booster?
I'm at the point where I want to swap my axles to Disco discs.
My question is whether I need to get a new Brake master cyclinder for the rear disc brakes?
I know I need the proportioning valve, but will the Master work?
I was told the disco master cyclinder would work, but both the Boosters I have(one from my1985 and another I got from Dale from a late model truck) have the bolts for the booster perfectly horizontal.
On the disco master they are a bit off horizontal. like 11 oclock and four oclock
What are my options?
Old October 2nd, 2009, 11:01 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No, just roll the disc brake axle under and bolt it up. no other bits are needed, the standard booster ("servo" here in correct-speaking-land ).
It's a very popular modification here, and the brakes are still up to the ministry test standards. too much boost and you can end up with the back end locking before the front (although i've never managed that myself!)
Old October 2nd, 2009, 12:14 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So you don't even use the proportioning valve from the disco?
Old October 2nd, 2009, 04:15 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No.
some model defenders have the proportional valve, some don't, not exactly sure of the reasoning for them, but just hooking up the disco axle to the original drum braked pipes and booster works fine... certainly better than the drum braked set-up.
boost, brake
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
Brake Servo / Booster -- Any Interest For cheap group buy??? Heath For Sale - Parts 6 August 12th, 2006 07:05 AM
