Brake Bleeding Sequence?? - Page 2 - Defender Source
Old April 14th, 2009, 12:32 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by crown14
I assume you bench bled the master?
Isnt there a proportioning valve on the RH side of the bulkhead?
Yes, the valve is on the right side foot well...
Legend in My Own Mind.
Old April 16th, 2009, 01:00 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Bled the brakes again today... No air in them. My guess is that it is the vacuum pump on the tdi. I took the pipe off and there is barely any suction at all.. DOes anyone know what the vacuum should be at idle?
Old April 21st, 2009, 04:37 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
replaced the vacuum pump today on the engine... Fixed...
bleed, brake
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
brake bleeding redrover Defender Technical Discussions 2 November 18th, 2004 07:21 PM
Brake bleeding help!! Bowtracer Defender Technical Discussions 5 May 18th, 2004 02:24 PM
