Brake bleed screw size - Defender Source
Old December 8th, 2014, 06:04 PM
I'm thinking of swapping in the speed bleeder type ... just to make my life a little easier.
Does anyone know the size for a NAS defender?
J
bleed, brake
Screw size for fan shroud ini88 Defender Technical Discussions 12 December 6th, 2014 07:08 PM
2.5td wont start unless pump bleed screw open msomers Defender Technical Discussions 11 July 2nd, 2013 02:53 PM
Rear brake caliper stuck / won't bleed nathanwind Defender Technical Discussions 3 March 16th, 2012 08:25 PM
Instrument Console Screw Size? 94 DMSLongLake Defender Technical Discussions 0 June 17th, 2010 02:39 PM
Vent cover screw size Buckon37s Defender Technical Discussions 10 April 25th, 2007 05:34 PM
