brake and clutch pipes DIY??? - Defender Source
Old September 4th, 2007, 11:48 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
So I'm gonna make my own clutch and brake pipes. You can buy Russell and other brand stainless steel pipe section for around $40 from Summit Racing and I read on ORRP all the time the Brits do it. I have no idea what I'm doing. What tool do I need to flare the end of the tubing? what diameter tubing is required? and what size are the fittings on the flex pipe (clutch and brake for the female fittings, master cylinder(clutch and brake) for the male fittings? Anyone done this or proficient? I didn't see any old threads. RN, AB, and the usual suspects ask a F-ing fortune for this... around ten times the cost. I'll call Summit in the AM, they're closed now. This'll add to the "built not bought" quality of my 90.
I'll post pics and notes when I get it done in case anyone else wants to save a fortune.
Keith
Old September 5th, 2007, 12:55 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I wanted to do the same thing, but am also unsure of the exact fittings. FYI, Summit is 24hrs unless they have changed in the last couple years.
Old September 5th, 2007, 11:48 AM
rgrrvr's Avatar
rgrrvr
1995 D90
I'll let you know what I come up with
Old September 5th, 2007, 03:26 PM
hi
I built a coil sprung hybrid for a guy here in DC using all hand made brake lines. I used defender and range rover axles and had to use the ISO flaring kit. Don't know if that was the right kit but the lines are still holding 7 years later.
I probably had to make some double (trumpet shape) flares as well, best to get both sets.
the fittings were all metric IIRC and were sourced from BGC Motorsports in the UK shipped direct to my house. The line was not stainless but you want 3/16 or the metric equivalent.
rgrds
dave
Keith
Old September 5th, 2007, 06:40 PM
bgc site
go here and scroll down
http://www.bgcmotorsport.co.uk/newbrakepart.html
Originally Posted by Ren Ching
hi
rgrds
dave
Old September 5th, 2007, 09:02 PM
rgrrvr's Avatar
rgrrvr
1995 D90
Thanks!!!
Old September 6th, 2007, 09:18 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You might want start with just the clutch and live with that for a good while. Something that isn't quite as potentionally lethal to others on the road. Or have someone working with you who does know what they are doing.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 6th, 2007, 01:24 PM
rgrrvr's Avatar
rgrrvr
1995 D90
Thanks for the heads up but I don't think its that hard to screw up, either it seals or it doesn't.
Mebbe I'll take it around the neighborhood a few times first and try stopping at the crosswalks.
Old September 6th, 2007, 01:42 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Well, actually it is. Mounting points, methods of mounting, stainless is quite different from carbon steel as far as working it, brittleness, type of construction of the tubing.
Also brake tubing has to be DOT approved, so that might even be a consideration for you (from the insurance/liability perspective).
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
brake, clutch
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
'71 Series IIa - $6,500 Winston-Rover For Sale - Vehicles 15 August 25th, 2009 12:43 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
