brake & abs light on - Defender Source
Old March 27th, 2013, 11:59 AM
Baja 90
Raul
97 D90, 94 RRC
Hi guys, changed the abs pump in the 94 RRC. The ABS and brake lights stay on. Pump/brakes are working fine. Any ideas? Is this common?
Raul
Old March 27th, 2013, 12:07 PM
ECU recorded an error. Duh, you know that. I am unsure whether simply unplugging power to the ECU for a while will clear the flash memory/error codes or not. Costs nothing, so worth a try. You'll have to reset the clock!
Old March 27th, 2013, 12:19 PM
Baja 90
Raul
97 D90, 94 RRC
Thanks! I'll try that and let you know if it worked.
Old March 27th, 2013, 12:20 PM
It should reset after a while by itself. You could have an actual fault with a wheel sensor or something too.
Old March 27th, 2013, 12:26 PM
Baja 90
Raul
97 D90, 94 RRC
If there was a fault it would give me a code right?
Old March 28th, 2013, 09:04 PM
Baja 90
Raul
97 D90, 94 RRC
No luck. Disconnected the ECU and the lights came on. Every once in a while they'll go off for a minute or so, but then right back on. I'm not getting a fault code.
Any ideas?
brake, ht
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
