Bottom link rubber bushings (NTC9027) - Defender Source
Old October 23rd, 2011, 09:48 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Why it's 13.95$ for one at Atlantic British and 59.95$ for a pair at RoversNorth ? I mean, none is stated as G and this is a huge difference.
- Charles Eames
Old October 24th, 2011, 11:23 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
aftermarket vs OME
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old October 25th, 2011, 09:01 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by roverx View Post
aftermarket vs OME
Do you have any personal experience with one or
the other ?
Seems difficult to find the LR genuine stuff for this part.
- Charles Eames
Old October 25th, 2011, 09:24 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Depends on the intended use. I tried the OE rubber and they lasted a year with trail use. I now have all poly bushings and am happy so far. My OE rear arm to chassis bushing literally squished out, and one front arm to axle bushing disintegrated.
Semper Fi!
Old October 25th, 2011, 10:07 AM
good to know as I have to replace my rear bushings soon.
Old October 26th, 2011, 03:29 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If you find some genuine replacement bushings, let me know .
- Charles Eames
90, bushings, rubber
SG 3 Link Bushings Needed TDI Guy Defender Technical Discussions 19 March 7th, 2010 12:47 AM
New Rubber Suspension Bushings redrockrover Defender Technical Discussions 12 September 8th, 2006 02:55 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
