Bottle Jack Maintenance? - Defender Source
Old February 2nd, 2004, 12:45 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Has anyone changed the fluid in their bottle jack?
How much fluid?
How do you fill it?
How do you bleed the air out of the system?
EwS
Old February 2nd, 2004, 04:37 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Haven't a clue Eric. Is it broke? I have seen them fail - my brothers was tanked, from a 1995 Classic. I think it wasn't stored right side up though, could have ruined it.
Old February 2nd, 2004, 09:47 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Wicks,
worked fine on my last flat. I turned the release valve too much and fluid drained. Just want to top it off. I found the fill plug, so hopefully it will work.
I hope to god it isn't toasted because they retail for 150!
Old February 10th, 2004, 07:58 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Originally posted by Eric Siepmann
Wicks,
Same thing happened to mine, and it hasn't worked since. I put more fluid in the fill hole, but there must be some bleeding procedure I'm not doing right.
Old July 14th, 2007, 12:41 PM
artm
Arthur Maravelis
97 SW
Thought I'd revive this thread with some useful information:
http://www.hyjacks.com/H7.HTM
I recently took a trip from Boston to Suffield, CT in the 110. This truck has a set ofBFG AT's fom my90. The 90 was bought with 70K miles on it and I put another 5K miles on these in the 110. They still had plenty of tread. Now I don't know if these were originals on the 90. I know they're a long lasting tread but who knows.
Anyways, took the Pike and 92S, all went well until we pull into the parking lot for my niece's soccer tournament. I hear a hissing sound, air leaking from the RR tire. Damn! Looking at it, it's not a flat but a tear in the sidewall - a substantial tear of 3-4 inches. A closer look revealed "crack" limes from the outer tread pointing in about 1-2 inches all around this tire.
The FR tire also looked prety bad so I got worried about making it home safely. I tracked down a local tire shop and bought a set of nwe ones.
Stepping back a bit - take out my trusty LR bottle jack, which has never been used, and it's low on oil! I can only raise it an inch! Fortunately a local lent me his mechanical minivan jack and I replaced the tire.
At any rate, picked up some fluid and filled both of them. However, I'm leaning toward the mechanical type. Sure, a hell of a lot more work, but a hell of a lot less maintenance.
Old July 14th, 2007, 01:47 PM
themaxx's Avatar
themaxx
Ade
94 ST
Mine is a bookend.
Old July 14th, 2007, 05:58 PM
mine is dead also and i cant get it to work. I accidentially let all the fluid out when i was installing some springs
Old July 14th, 2007, 08:50 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
If you want another one, call English-Swedish Spares in Alpharetta, GA.
They had a couple sitting on the shelf that were used last time I was in there.
Old July 15th, 2007, 12:04 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Somewhere on the Source is information on bleeding the LR bottle jack. It's from a couple of years back.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
ac
bottle jack monsignor Defender Technical Discussions 15 July 9th, 2009 11:57 PM
Stock Bottle Jack and Lever for 94 D90 Happyxhour Wanted 5 August 6th, 2007 08:28 PM
LR genuine bottle jack Overlander Wanted 3 March 6th, 2007 03:31 PM
Missing Lever for Bottle Jack on 97 D90 ClanHavoc Wanted 0 May 27th, 2006 09:22 PM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
