bostik - Defender Source
Old October 17th, 2003, 01:53 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
bostik
The pedal and brake boxes call for bostik adhesive when refitting. Is this stuff available, or can someone reccomend a similar product? Appreciated. In the midst of Master Cylinder jobbie.
Old October 17th, 2003, 03:12 PM
If the Land Rover dealer does not have it then I would guess you do not need it. Is it like Lock-tight?
Old October 17th, 2003, 03:24 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
it is used like a caulking to seal the housing to the bulkhead. the only reason I could think of is to stop water egress into the cab.
That being said, I did not reapply when I replaced my MC... not much water here in So. Cal.
Who knows... maybe I'll regret that...
Insert pithy quote here.
Old October 17th, 2003, 04:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just use something like permatex gasket sealer in black. That is all that is. It makes a gasket between the 2 metal surfaces so no water (or less water) dripps on your feet.. That is what I will be using as I start putting my bulkhead back together
Old October 17th, 2003, 08:51 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
I ended up using some of that black window goo that comes in a roll. It sucked. I have it all over myself.
It's done though!
