Bosch VE parts? - Defender Source
Old July 6th, 2016, 09:08 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Bosch VE parts?
I want to buy a new spring for the fuel pin rather than just give it less travel by turning the star wheel, anyone know where I can buy one?
It's on a Defender 200tdi.
Thanks!
Pablo
Old July 6th, 2016, 10:52 PM
carlosz's Avatar
carlosz
Carlos
try Scott at united diesel on general washington drive of edsall rd.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old July 6th, 2016, 11:01 PM
What are you trying to accomplish? The star wheel sets the spring pre-load, thus it sets at what pressure the pin starts to move. It does not affect the travel. A spring can't "go bad", so sticking in a new one of the same spec will do nothing. Are you trying to find a spring with a different rate?
Old July 6th, 2016, 11:20 PM
PabloCocito
Pablo Cocito
I was told that springs will soften up with time and change the fueling rates when building boost, but I guess not? My truck smokes when it's building boost, but once boost is reached it stops smoking, and if I get on the gas hard again it'll smoke until boost is built up. A weak spring makes sense as its only when I first accelerate.
Maybe I just need a good pump tuning but I have no idea how...
Sent from my iPad using Tapatalk
Old July 6th, 2016, 11:26 PM
A spring can't change rate. You can reduce off boost fueling to lower smoke when not on boost. The first thing to back off is the external adjuster on the top of the diaphragm cover. That will reduce off boost fueling with no effect to on boost fueling.
Old July 6th, 2016, 11:43 PM
PabloCocito
Pablo Cocito
The smoke only comes on when boost is starting to build up, but once I'm holding a steady, say 10psi there is no smoke, or very minimal, but when it's ramping up to that 10 psi it smokes a decent amount, unless it builds pressure very slowly then there's no smoke.
Old July 6th, 2016, 11:54 PM
You can only adjust what happens at full throttle and there is not really any way to be at part boost and full throttle for any period of time.
You are saying there is no smoke at full throttle below 1500 rpm where you can't make boost?
Raise the star wheel (counterclockwise) to increase preload so that the boost pin moves a bit later if you want to reduce partial boost fueling.
There is always some delay. The turbo can only produce boost with enough fueling and the fueling only increases after there is boost.
Old July 6th, 2016, 11:56 PM
You have to also watch what is you peak boost. The stock 200 spring with limit stop maxes out around 12 psi. Above that you get no more fueling increase. If you run smokeless at 15 psi you need to be overfilled at 12.
Old July 7th, 2016, 12:39 AM
PabloCocito
Pablo Cocito
I'll try to turn the star wheel clockwise and see if that helps. If I'm at 1500 rpm and floor it it'll smoke, and then if I back out a little bit and hold it there then the smoke clears up
Peak boost is 12-12.5psi
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
FS: D-90 Bosch AMR 4247 Alternator dzientek For Sale - Parts 1 February 8th, 2007 07:15 PM
Bosch 4.6 Engine FOR SALE RedRhinoProducts For Sale - Parts 8 February 21st, 2006 10:53 AM
GEMS or Bosch boxerhips Defender Technical Discussions 34 January 5th, 2006 05:25 PM
Bosch Alternator tmore Defender Technical Discussions 0 April 9th, 2004 11:46 AM
