Bosch VE Gauge - Defender Source
Old May 5th, 2016, 02:16 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Bosch VE Gauge
The only diesel IP specialist I know of and trust in the area does not own a gauge for my dinosaur of a IP. Can someone confirm this dial gauge will likely do the trick?
If there is anyone local that has one I can rent please send me a smoke signal or grab the other end of this can and string.
Amazon.com: Diesel Fuel Injection Pump Timing Indicator Tool for VW/AUDI/Ford etc...: Automotive
Old May 5th, 2016, 02:21 PM
Should work, but are you serious? The VE pump is commoner than dirt. You understand this is just for setting the timing?
A cheaper option with your own dial gauge: http://www.amazon.com/BOSCH-INJECTIO...osch+ve+timing
Old May 5th, 2016, 02:55 PM
1of40's Avatar
1of40
1of40
Wish I weren't but there are not many folks with a Bosch shingle hanging in front of their shop around here. This shop owner is someone I feel I can trust so it's worth some investment IMO.
I'm plotting out options to deal with what I think is a fuel issue. At least I'd like to know if the settings are standard or not. Right now the idle is rough with strong vibes when engine is cold. More IMO than what I even experienced with my old 2.5NAD. The road manners actually seem good, maybe even above average but it is currently idling at 850+ and can't get it to drop.
Old May 5th, 2016, 03:20 PM
Which engine? I say this because on a Defender 200TDI, there is not room to use a dial indicator on the vehicle.
I would check injectors first.
Old May 5th, 2016, 03:27 PM
1of40's Avatar
1of40
1of40
Ha!, figures, and about par for the course so far with this swap. It's a Disco 200 in a Defender btw.
Injectors were recently rebuilt with new Bosch nozzles. Lord knows there are no guarantees that the nozzles are any good though.
Old May 5th, 2016, 03:31 PM
You might be able to with a Disco engine. With the Defender, the oil filter housing is in the way.
Did the person that did the injectors have the proper equipment to set and balance the two stage injectors? Not many do...
Old May 5th, 2016, 03:35 PM
1of40's Avatar
1of40
1of40
I feel like I should double check. Blue Ridge Diesel is considered a great shop hear in VA and the guy assisting me is a 200tdi owner. I can ask to be certain.
Old May 5th, 2016, 03:51 PM
Originally Posted by 1of40 View Post
...,Right now the idle is rough with strong vibes when engine is cold....The road manners actually seem good.....
Sorry to hear that Clay - along the the lines of misery loving company, I'm experiencing the very same symptoms at the moment with our 200Tdi...
Old May 5th, 2016, 04:10 PM
1of40's Avatar
1of40
1of40
Damn, you have the flu too? Yeah, these engines can be much more complex than I ever realized. Many will disagree I'm sure. The lack of widespread skill and knowledge (even tools) is a factor that I'm concerned about. I fantasized of using this for trips and stuff that I can't imagine doing at this point. I'm about 20 years late to the ball.
Old May 5th, 2016, 04:18 PM
I'm still confused about the lack of knowledge on the pumps. Every VW/Audi for 10 years. Every Cummins diesel for a decade. I can't imagine any diesel shop not having a huge amount of experience with them.
Robert Bosch VE-type Injection Pump
Old May 5th, 2016, 04:41 PM
1of40's Avatar
1of40
1of40
Well, it's either me or the shops in this general area have moved on and work primarily on different set ups. The shops I have called say "we haven't worked on that stuff in ages". The shops here have more work than they can get to so they outright say they can't help. Same goes for driveline specialist. 40 million people in the DC area and one driveline shop. It's silly.
BTW, Blue Ridge Diesel just called me to confirm my injectors were a two-stage set up. They're 4 hours away and still believe in calling people back ASAP.
Old May 5th, 2016, 05:07 PM
LOL...I thought the same thing. Once it warms up, it's good to go. But a cold start, not so much. It's a rough idle cold start up. At cold start, it gasps for life a couple of times, and then it begins a cyclical - almost rhythmic - surging and backing down pattern (with plenty of vibration during the surges) until it warms up.
Once warm, the idle seems rather normal to me and not too high, but I don't have a tach on it.
Old May 5th, 2016, 05:09 PM
Clay don't buy anything.
I think you may need adjustments on the max fueling and/or smoke screw.
Also check to make sure there are no loose fittings like we talked about.
For all who are following the build:
The engine was running like dog shit when we first put it in. Sounded like injector nailing. Engine was shaking so bad you couldn't get a screwdriver on the idle speed screw and everything on the car was moving. The dipstick end was a blur.
So, then we got the injector tips replaced @ Blue Ridge and yes they are properly set up to do the two stage testing, shimming etc. After that it was much happier, IMO running normally @ 750rpm according to the crappy iPhone app. But the head gasket was leaking oil at the front right corner where the rockers' oil feed is.
So, we took the head off and re-checked its flatness and came up showing more warp than the first time so we got it skimmed. With all the valves lapped in the engine runs even smoother than before. But, now the idle won't go below 850 (based on ear and same crappy iPhone app)
IMO when I left Clay's, the engine was running fine and not rough at all. There is a slight but noticeable quieting after a minute or so once everything warms up. Which is normal for an old mechanical diesel IMO. I'm not sure what happened during the head gasket replacement that caused the idle speed to change, but I have some ideas where to start.
Going over in my head everything we did, I suspect that I may have left the bolts slightly loose on the intake manifold though I doubt that would cause any real issue. Also thinking it is possible that one of the IP fittings where the hard lines attach may have come loose in removing the lines. But, don't recall noticing that or seeing any leaks.
The only other thing I can come up with is that the engine is making better compression and that the max fueling is now too high due to someone turning it up to improve power on what was previously a pretty sad and worn-out motor.
I am surprised to hear that United Diesel doesn't have the adapter to check lift on a VE pump.
In any event, Clay, remember that this condition was an immediate change between how it ran before we did the head and how it ran after. Nothing changed during the two or three weeks your truck sat in the garage waiting for the head to come back.
The first thing is to re-check everything we did before you go messing around with stuff that we didn't change. I hope that makes sense.
Yes diesel is great when it is working. Diagnosis can be a bit mysterious if you are used to working with gas engines but not so difficult if you follow a logical path of steps.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 5th, 2016, 06:29 PM
1of40's Avatar
1of40
1of40
Thank Dave, injection pipe fittings checked good and the manifold bolts checked good.
My queries today are for exploring options and more importantly how I'm going to learn this stuff. When I read the inner workings of the IP it is complex and it makes sense to me that the settings are checked.
As you know this engine has been beyond disappointing on a number of levels and for a number of reasons so my confidence in a major component that hasn't been looked at properly is ultra low.
I still have exhaust and temp sensor to address before this high idle issue.
Re United Diesel, that guy Scott is pretty cool. I called him yesterday and he was more than willing to listen to what the issue is even though his shop does not do this old stuff anymore. He asked me to send him the serial number on the IP which I did. He later emailed me about 4x with additional questions up until about 10pm. He's willing to help with additional testing but he doesn't have the dial gauge needed.
Things will be fine once I smarten up and start understanding this machine and I start trusting its not planning another curveball.
Old May 5th, 2016, 07:02 PM
Out of curiosity, how far out is the idle stop screw on the pump (fender side of the throttle butterfly) ?
What you describe sounds like a fueling adjustment issue, ie not enough @ idle.
Had one last week that was changing hands between two forum members and when I drove it it felt anemic.
The idle stop on the butterfly was adjusted way out to get the truck to idle smoothly which it did, but overall the engine seemed weak.
It would pull a mountain in 5th when it left.
Old May 5th, 2016, 07:32 PM
1of40's Avatar
1of40
1of40
Out of curiosity, how far out is the idle stop screw on the pump (fender side of the throttle butterfly) ? What you describe sounds like a fueling adjustment issue, ie not enough @ idle. Had one last week that was changing hands between two forum members and when I drove it it felt anemic. The idle stop on the butterfly was adjusted way out to get the truck to idle smoothly which it did, but overall the engine seemed weak. It would pull a mountain in 5th when it left.
This?
Old May 5th, 2016, 07:57 PM
Yes, that's turned pretty far out.
Is the tamper proof collar still on the max fuel screw on the back of the pump ?
Old May 5th, 2016, 08:30 PM
....Had one last week that was changing hands between two forum members and when I drove it it felt anemic. The idle stop on the butterfly was adjusted way out to get the truck to idle smoothly which it did, but overall the engine seemed weak. It would pull a mountain in 5th when it left.
I need to come to God's country.
Old May 5th, 2016, 08:45 PM
Sure man, although yours needed more than tuning last I heard
Old May 5th, 2016, 09:14 PM
lol - that has been taken care of (famous last words)
i'll pm you
Clay - sorry I had a hijack in your Bosch VE thread
bosch
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
FS: D-90 Bosch AMR 4247 Alternator dzientek For Sale - Parts 1 February 8th, 2007 07:15 PM
Bosch 4.6 Engine FOR SALE RedRhinoProducts For Sale - Parts 8 February 21st, 2006 10:53 AM
GEMS or Bosch boxerhips Defender Technical Discussions 34 January 5th, 2006 05:25 PM
Bosch Alternator tmore Defender Technical Discussions 0 April 9th, 2004 11:46 AM
