Borg Warner Help - Page 2 - Defender Source
Old November 17th, 2014, 01:17 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Was it the U-joint at the diff ? Hard to tell in the pic but it looked not right .
85 D110 3.5 3 DR
Old November 17th, 2014, 02:05 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I think the things US Customs is concerned with are EPA, safety regs, and year.
Since transfer case doesn't fall into any of those categories I would say it's safe to pass.
Black Rhino Lives Matter
Old November 20th, 2014, 10:18 AM
lbwhotrod
Les Wlton
91 D90
Ed -It was the u joint on the rear diff, two of the bearings were completely dry with out grease, the other two were greased but worn out. I bought a used truck, so I expected that some things needed to be worked.
Luis- your right, I finally got a reply from US customs department and they said that my combination and time when I bring it back is not a problem. I saved that email, just incase. Since I am falling under the 25 years and older I will be good and shouldn't have any issues.
------ Follow up post added November 20th, 2014 04:21 PM ------
So update on my combination. The last owner came clean, the engine blew two years ago and he replaced everything out of RRC. So engine, trans, and t-case are all out of RRC. Now I get to play and see what he kept and what he didn't.
I do want to thank you guys, he had told me everything was stock and that he had the original build sheets. When I asked for them that is when the rest of the story came out.
1991 D90. Love the personality, now just need to give her new head lights, lift up the front and rear, a nose job and something to dress up the tail.
200TDI, LT77, BW t-case.
Old November 20th, 2014, 10:48 AM
See post #2.
Old November 20th, 2014, 02:19 PM
lbwhotrod
Les Wlton
91 D90
Bill thank you. I was lucky the fronts were not also taken out.
Old November 21st, 2014, 10:18 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Make sure you have the correct fluid in the tcase if you haven't already
borg warner tcases. draaronr For Sale - Parts 0 December 11th, 2013 04:09 PM
Borg Warner T/C lynchee For Sale - Parts 0 August 29th, 2013 01:41 AM
RRC 3.9, auto transmission, and borg warner vtrover For Sale - Parts 0 December 7th, 2012 08:36 PM
Borg Warner Transfer Case Shifter Linkage (RRC) cellulararrest Wanted 2 August 22nd, 2007 01:20 PM
BORG WARNER juice rover4x4 Defender Technical Discussions 0 January 20th, 2007 05:26 PM
