Bonus light connectors?!? - Defender Source
Old April 19th, 2011, 11:51 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Hey Guys,
So I'm in the process of switching over to a 95+ bezel and turn signal and while disconnecting the lucar connectors I found some bonus wires back there. They have the same plug, which fits the 95+ turn signal but one is hot when the light are on and one doesnt seem to be hot for anything, except the positive wire on that connector has continuity with the positve wire on the stock 94 turn signal. But if you put the flashers on you don't get the 12ish volts only mV so essentially nothing.
Anyone know what these are? There is the headlight, stock turn lucar, + and - running lucars, and 2 bonus in the pic.
All this is in preparation for the Rockware bumpers that are coming. Still have yet to do the auto console I got from Ashcrofts, but it looks pretty good. I plan on doing that along with a iron goat center console and a painless heavy duty fuse block. I got some of the tuffy rear storage boxes too, so yet another thing to do. But now I just want to drive the thing!!! LOL.
Thanks.
Pete
Old April 20th, 2011, 04:10 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Are you talking about the green and black with bullet connectors? Could be for a sidelight bulb in the headlamp. If they were for the wing lights they would only work with the turn signal, not the headlamps. Is it solid green or is there a trace color?
Plain black is always a ground wire in British standard.
British Standard wiring guide
Tony
1984 110 "Smokey" (sold)
Old April 20th, 2011, 07:34 AM
Broncoduecer
peter
D90
I was talking about the two white connectors in the middle. I know what all the bullet ones are. I think looking in a parts catalog shows that they are for the running lights but just a sealed connector. If i was reding the parts catalog correct. Just seems odd to have both.
Old April 20th, 2011, 07:49 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Late 94 and early 95 NAS 90s had the wiring set ups for both type of front lights. One plug should have red/black wires (parking lights) and the other should be green/white (RH side turn signal)/black, and green/red(LH turn signal)/black respectively.
If you are going to the new style lights it should be plug and play.
The red wire for the parking lights can also be red/black and red/orange depending on the build date.
Email:
Old April 20th, 2011, 09:06 AM
Broncoduecer
peter
D90
Oh cool. Maybe I just wasnt getting the probes in there far enough.
Thanks!
Pete
Old April 21st, 2011, 05:44 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Sorry, I didn't realize the NAS lights used a different connector, those white ones are the turn and sidelight connectors on my truck.
Tony
Old April 21st, 2011, 08:14 PM
Broncoduecer
peter
D90
Agh rats! Turns out they are both parking lights. I might snip one bonus connector on each side and use the bumper light wires with some butt connectors or crimps or something. I thought it was going to be easy! Well not thatits hard, just thought maybe no wire cutting. What would be funny if the left side had turn and running in the bonus connectors.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
