Bonnet stay (hood support) - Defender Source
Old July 1st, 2014, 01:06 PM
richord
Richard Ordowich
1987/D90
I can't figure out why my hood support doesn't work. Here are two pictures.
Is there something missing or broken?
ID:	97924   Click image for larger version
Name:	Bonnet stay 2.jpg
Old July 1st, 2014, 01:49 PM
rovertrader's Avatar
rovertrader
Dale
What's not working?
Old July 1st, 2014, 05:53 PM
richord
Richard Ordowich
1987/D90
The stay folds down if i let go of the hood. It does not latch up. I have to use a board to keep the hood up.
Does anyone have a photo of what it looks like when latched open? A photo if the arm and the latch at the bottom would help.
Old July 1st, 2014, 06:09 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
its folds in the middle forward to stay open,the bar sits against rad bracket and you lift and fold it back to close, Right
nothing looks out of sorts in the picture
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 1st, 2014, 06:47 PM
richord
Richard Ordowich
1987/D90
Mine does not forked forward, towards the front of the truck. I can't lift the hood high enough to get it to fold towards the front of the truck. The bottom near the radiator bracket is bent and doesn't slide up high enough I guess.
Old July 1st, 2014, 07:00 PM
the photo that matters is where the two rectangular sticks intersect/cross, not where the sticks attach to the bonnet/slam panel.
Old July 1st, 2014, 07:07 PM
richord
Richard Ordowich
1987/D90
i would appreciate a photo of what the arm looks like when supporting the hood.
Old July 1st, 2014, 07:28 PM
roverman2010
1985 LR 90 200Tdi
hope these help
ID:	97944   Click image for larger version
ID:	97946   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old July 1st, 2014, 07:51 PM
Richard: why is your radiator top bracket interfering with the support? Someone had cut into it.
Can you zoom out a bit?
I'm thinking you may need to remove the hood.
Old July 1st, 2014, 07:52 PM
richord
Richard Ordowich
1987/D90
Great, thanks for the photos. I think I know what the problem is with mine.
Old July 4th, 2014, 06:13 AM
richord
Richard Ordowich
1987/D90
I discovered the problem. My arm was installed backwards! Someone must have taken it off and installed it the wrong way. Once I flipped it over it works fine.
Now I don't have to wear a hard hat when I work under the hood
hood
Td5/Defender Hood, Grille & Rad Support hye1978 Wanted 3 June 10th, 2011 03:39 PM
Puma Hood and Hood support CDeWan Defender Technical Discussions 1 June 9th, 2011 11:51 AM
Hood/Bonnet Support Bracket Chris Vitale Wanted 9 November 1st, 2010 02:01 PM
Feeler: Defender hood (bonnet) with hood pins? Buckon37s For Sale - Parts 7 July 10th, 2010 05:18 PM
WTB/WTT White Bonnet / Hood for RN hood tire kit woldd90 Wanted 7 January 15th, 2008 11:49 AM
