Bonnet Release Issue - Defender Source
Old October 18th, 2016, 03:15 PM
aosias's Avatar
aosias
Alexandra
1995 D90
The 110 had homemade release for the bonnet. It was an extension handle welded onto the original release from the original grill. It was "fabricated" when AC was added and the push out grill.
The handle snapped off today and now if I close the bonnet I don't know how I will be able to open it. Is there a way to release it with a screwdriver or any other idea?
Alex
Old October 18th, 2016, 04:30 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Remove it and install something proper.
A hood jammed closed is a pain in the @$$.
RDavisinVA
Old October 18th, 2016, 05:25 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
I don't have any inspired ideas, but can you remove the broken latch and weld on a new extension?
While my bonnet latch works (mostly) the lock does not. If you happen to find a vendor selling the lock / latch / release arm mechanism let me know, please.
Old October 18th, 2016, 06:01 PM
chuckc4
chuck b
Registered User
Alex
You could pull off the grill and add an extension to the wire that goes to the mechanism so you could release from the front of the vehicle. you would have to route the cable so you were not pulling perpendicular to the front of the Defender.
Old October 18th, 2016, 06:06 PM
Put a loop in the wire. Then pull on the loop. Mine has been this way for years.
Old October 18th, 2016, 06:17 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Alex do you have a cable release or a manual release, sounds like you have the early manual lever release and not the cable.
RDavisinVA
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
Bonnet Release Cable Clip -- Please Help! jefhuf Defender Technical Discussions 4 June 19th, 2010 10:55 PM
Bonnet/bonnet tire mount kit Brent Nevin Wanted 1 April 4th, 2010 05:10 PM
New Take Off Bonnet / 08 Bonnet for sale SafariHP The Vendors Loft 1 December 23rd, 2008 08:40 PM
Bonnet Release Cable TDI Guy For Sale - Parts 12 December 2nd, 2004 05:44 PM
