Bonnet Release Cable Clip -- Please Help! - Defender Source
Old June 19th, 2010, 09:58 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
My bonnet release cable on my D90 stopped working so like most I ordered up a new one before even bothering to look at it...further investigation while installing the new cable revealed that my real problem is that the small clip that holds the cable in place by the latch is gone. Does anyone have one of these they would like to donate/sell or know where to find small random parts like these?
Old June 19th, 2010, 09:59 PM
Tie a double knot in the cable. Later ones have a bolt that holds it in place which is much better.
Old June 19th, 2010, 10:02 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
To clarify, I have the bolt/barrel nut that "attaches" the cable to the latch...what I am missing is the metal clip that holds the cable housing to the radiator support. Basically, when I currently try to pull the handle to open the latch, the whole cable assembly (inner cable and outer housing) flex and don't pull the lever to release the latch
Hopefully this photo helps (don't criticize Galpin's mean photo skills!)
Old June 19th, 2010, 10:45 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
To make it work "temporarily" you could take a bit of the old inner cable, attach one end to the latch and attach the other end to the body behind the grill. That's the way mine was when I got it, and it works fine, if you're not a purist. The cable angles down, so I just stick my fingers through the grill (third slot from the top) and pull it.
John Karlsson
Hope Valley, RI
Old June 19th, 2010, 10:55 PM
Ah, I see. NAS 110s are a bit different.
Defender / Series Door Hinge Kit / TD 5 Bonnet Cable SafariHP For Sale - Parts 1 August 25th, 2007 09:58 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
Bonnet Release Cable TDI Guy For Sale - Parts 12 December 2nd, 2004 05:44 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
