Bonnet mounting config for steel wheels? - Defender Source
Old January 13th, 2004, 06:23 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Unhappy Bonnet mounting config for steel wheels?
What is the bonnet mounting configuration for steel wheels on the standard mount? Do I need some longer studs, etc.? or is my engineering skill really depressed at the moment?
Thanks!
Wicks
Name:	wolfe bonnet 1.jpg
Old April 24th, 2011, 07:34 PM
Worldrover1's Avatar
Worldrover1
Race
1995 NAS D-90 SW/#361
I just did a steel wheel on mine. There are four bolted rubber posts that hold the tire just off the bonnet. the bolts should work for both alloy and steel. The line up for the elevated rubber bolts is under your bonnet. Look at the reinforcing rails and there should be x4 holes already drilled in the reinforcements. those are your markers. They should be about 15" apart. draw a line from hole to hole forming an "X" in the center of your bonnet. that is your drill point for your center hole. then you will need to drill two more holes, one just to the left and the other just to the right. these should line up with your mounting bracket. The bracket and rubber elevating bolts are key here. I also had to order a stronger bonnet spring from England in order to have the bonnet release properly under the weight of the spare.
Old April 24th, 2011, 10:02 PM
I believe the only difference between alloy and steel wheel bonnet mounts is the retainer (the part that comes off). I have the steel version on mine.
good info on the different spring! What's that part no? I need it!
Old April 24th, 2011, 10:23 PM
Digging up a thread from 2004...
Old April 25th, 2011, 01:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I think I have one. You can have it if I do for cheap.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
mount, steel wheels, wheel, wheels
Bonnet Mount Spare Adapter for Alloy Wheels Manimal Wanted 0 March 14th, 2009 12:47 AM
Disco II / Range Rover Wheels rvrnut110 For Sale - Parts 0 November 9th, 2005 01:51 AM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
5 Allied beadlock wheels jdb3760 For Sale - Parts 3 September 20th, 2005 05:19 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
