Bonnet mounted tire: Risky? - Defender Source
Old July 26th, 2014, 01:04 PM
doscazadores
Vic Stull
none
I'm paranoid about tire failure in the middle of nowhere (hunting & camping trips) ever since I ripped a couple tires apart in a single day some years back. Have a '95 D90 ST in stock condition and am thinking about saving storage space if I carry another spare by putting it on the hood. But I've been in D90's in the past with that setup and the tire seems to bounce around so much the stress on the metal hood must be significant - and not good over time.
Am I worrying too much about it? If so, is there a way the hood can be reinforced to better handle the stress? Or, any options for carrying an additional spare somewhere else than inside where I need the space? Thanks for any ideas or insights. Vic
Old July 26th, 2014, 01:06 PM
I have a 50 year old series that seems to have held up ok with a tire on the hood the whole time. I say get the right fitting kit/backing plates and it should be fine.
Originally Posted by pendy
I'm here for the D's
Old July 26th, 2014, 01:10 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Get a roof basket and put the tire up there.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old July 26th, 2014, 01:27 PM
Somebody drops your hood once and you will wish you never started this thread. I eliminated my hood mounted spare when I tossed my deformed hood in the trash and replaced it with a new one. Have a local fab shop make you a dual rear tire carrier instead.
Old July 26th, 2014, 01:28 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
I believe NAS trucks were not allowed to have this because in crash tests the tire would end up in the passenger compartment. With that said, like posted above, seems to have worked well for many moons.
Old July 26th, 2014, 01:39 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
It depends on the tire size you are running. The stock tires on NAS d-90's are almost too wide for teh hood. It becomes difficult to see around. The narrower tires like on many ROW truck, are OK.
-Jeff
Agreed size matters...the original tire(s) would not have been so big. I like the Bonnet Mount but it's too risky. Do the dual rear mount or a nice rack/basket mount!
Old July 26th, 2014, 01:58 PM
87 D110 (Ruby)
Difference is our "leafers" were made for this Charles...and I agree with you. Matter of fact I will have a spare tire mounted there particularly for cosmetic reasons - I just think it is the coolest look and my road tires are too wide to mount up there.
LNBright
Leslie Bright
1972 88" SIII
Aside from running narrower tires, a lot of the Series bonnets were dished, to get the tire that much lower...
On a plain Defender hood, I'd not put the tire there... With the rear carrier, if you don't want a second inside, then I'd suggest the roof rack...
Old July 26th, 2014, 02:02 PM
the rover shop
shayne young
I have the tyre mounted on the hood on mine and I only did it because it looks cool..and the camels had it there... I did however install the 3mm checker plate kit on there..I will tell you it hinders sight a lot on technical sections.. And it stops a lot of airflow through the fresh air vents.. Did I mention it looks cool though) on my next build I will be doing dual mounted spares on the rear...that looks cool too..!!
------ Follow up post added July 26th, 2014 02:03 PM ------
If it's just for a...oh shit... Spare you could run a narrower, lighter tyre there and lessen the damage to the hood..
Old July 26th, 2014, 02:13 PM
Yeah a skinny spare should be fine. Forum member Ken Loy has been running spare on his NAS D90 hood for the last 10 plus years with no issues that I know of.
A rooftop basket is the last place I'd put one on personally. First its too much weight too high, second it's a convertible, and lastly, do you really want to hump a tire up there?
Old July 26th, 2014, 02:21 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Its a pita on mine. Wouldn't recommend it.
Old July 26th, 2014, 04:37 PM
doscazadores
Vic Stull
none
Thanks, y'all. My misgivings are confirmed; mostly. But I agree the tire up front does look cool, but something on the rear seems more practical for me. I wish Paul Rickard were still with us today because I know he'd be able to make something awesome for me.
And my suburban garage height won't allow me to put a tire on top. So the rear end is the obvious choice for me.
Thanks again. Vic
Old July 26th, 2014, 04:42 PM
Bill Larson
Bill Larson
Thanks again. Vic
You could call Matt @ Rockware in Colorado for an estimate.
Old July 26th, 2014, 04:48 PM
C391HAT's Avatar
C391HAT
Zach
86 110
The Snatch brush bars can hold a tire
Old July 26th, 2014, 04:53 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
And block airflow into the radiator.
Black Rhino Lives Matter
Old July 26th, 2014, 05:10 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Or the Wolf 90 mount. -Jeff
Different looking. It would have to grow on me. But better than hood even though it does look cool.
Old July 26th, 2014, 05:12 PM
Bill Larson
Bill Larson
-Jeff
I've always been fond of that look...
Old July 26th, 2014, 05:17 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
FWIW - I love my bonnet mounted spare. And like some have mentioned I am running a lighter weight skinny tyre on the bonnet as the second spare. The full size/weight primary spare is on a mantec swing away rear carrier.
I'm running the 3mm mammouth chequerplate with a frontrunner carrier.
Old July 26th, 2014, 05:29 PM
Brian - what size are you running on the bonnet? A 235 or similar?
Old July 26th, 2014, 05:35 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Michelin XZL or XL on a standard road wheel instead of the Wolf/NATO rims.
mount, tire
WTB: Bonnet-Mounted Spare Tire Parts sandman913 Wanted 3 November 23rd, 2013 10:30 PM
Bonnet/bonnet tire mount kit Brent Nevin Wanted 1 April 4th, 2010 05:10 PM
Bonnet Mounted Spare Tire WLDKGDM Wanted 6 May 14th, 2009 03:39 PM
Bonnet Mounted Tire Carrier floyd650 For Sale - Parts 4 December 16th, 2007 12:43 AM
Bonnet mounted spare tire flippedrover Misc. Chit-Chat 32 December 15th, 2003 06:37 PM
