bonnet / hood alignment - Defender Source
Old July 19th, 2005, 10:35 AM
jcasteel
John Casteel
1961 Series IIa
I've asked before but it's been awhile.
Has anybody successfully raised the back of their hood. On many of the Defenders, mine included, there is about a 1 inch gap at the front of the hood and the rear of the hood rubs on the wings. I wouldn't care except that I've rubbed through the paint and am concerned that I could rub a hole in the aluminum wing.
I've tried flipping the plastic hinge inserts which raised the hood only slightly. I've looked to see if the hinge is adjustable but it appears to be riveted in place.
One other option is to take a crow bar and try to bend the hinges up but I'm hesitant to do that.
Any suggestions?
1961 Series IIa 24100020a
2010 Surly Steamroller
1995 Red D90 (Sold)
Old December 27th, 2005, 09:12 AM
Mike Finn
Green Machine
1995 D90
John,
I noticed that the gaps between the bonnet and the wings are not consistant on mine neither. I plan on looking into this soon. If I figure anything out, I'll post it.
Old December 27th, 2005, 12:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The hinge, as you suspect, is not adjustable and is actually welded in place. The rub you are refering too is pretty darn common and not a lot you can do. I jumped on my wing to lower it a little (hahaha) which is not a factory recommendation. You can lower the wing a little at the risk of it not aligning with the doors by loosening all the bolts inside against the firewall but I would not since (a) it might not work and (b) it might not work. You can reweld the hinges if you want to repaint your firewall in that area (I have done this--I could not get them any higher since they are bordering on the air vent) but mine still rub even after this.
I am of the opinion, after spending a lot of time on this issue, that you are hosed.
Old December 27th, 2005, 09:29 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
One thought that might work if you are lucky is to fashion a custom hinge insert where the slot is not quite so deep so you can gain a little more height to the back of the bonnet, or perhaps you could place a little spacer in the slot on the present insert to give a little more height. Let us know if you come up with a solution.
Old December 28th, 2005, 08:24 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Why not shave the rubber bushing down that's in the hinges?
Old December 28th, 2005, 12:54 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Why not have the piece that is bolted to the hood as a hinge, surfaced to be thiner?
legend in my own mind
alignment, hood
Need a bonnet (hood) Green Blood Wanted 11 May 5th, 2009 11:46 PM
WTB/WTT White Bonnet / Hood for RN hood tire kit woldd90 Wanted 7 January 15th, 2008 11:49 AM
bonnet / hood for defender wanted haaseizhere Wanted 4 September 7th, 2007 12:29 PM
looking for a hood (bonnet) for a defender haaseizhere Wanted 1 April 20th, 2007 10:10 AM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
