Bonnet / Hood alignment - Defender Source
Old November 5th, 2004, 01:31 PM
jcasteel
John Casteel
1961 Series IIa
While working on my rat infested rover (See different thread). I removed the bonnet to better access the wiring loom. Now I'd like to fix another vexing problem.
My bonnet is rubbing the fenders at the back (closest to the hinges) while at the front there is a 1/2 inch gap between the fender and the bonnet. I've searched the forum and tried the fixes found there namely flipping over the black plastic hinge inserts. I've also adjusted the bonnet bumper stops that rest on the radiator surround.
Neither of these things worked. In the past I looked for an adjustment for the hinges behind the dash but as best as I can tell the hinges are riveted to the firewall.
Does anybody have a different solution?
Old November 6th, 2004, 10:07 PM
Well mine s kinda the same, gap at the front and rubbing at the back, I've never tried to fix it though, just thought it was normal for a hand madeish type vehicle.
alignment, hood
Need a bonnet (hood) Green Blood Wanted 11 May 5th, 2009 11:46 PM
WTB/WTT White Bonnet / Hood for RN hood tire kit woldd90 Wanted 7 January 15th, 2008 11:49 AM
bonnet / hood for defender wanted haaseizhere Wanted 4 September 7th, 2007 12:29 PM
looking for a hood (bonnet) for a defender haaseizhere Wanted 1 April 20th, 2007 10:10 AM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
