Bondo or NO bondo is the question - Defender Source
Old April 10th, 2009, 02:59 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
What is the best way on a Defender to get body dings(sometimes a run in with a tree ding, okay maybe Dong) out of the body panel?
I was going to use "Evercoat Rage" as the filler.
Would you get "Dent Wizard" on this or Filler, not sure how much the Wizard would charge for a whole truck but cant be cheap.
Would I be degrading the truck if I use filler?..One thing is true my baby and me wont be parting for many years to come.
Any suggestions/comments would be great
Old April 10th, 2009, 03:06 PM
I have seen someone use dry ice to pop small dings out of aluminium, but for anythign with a crease you are stuck with bondo or replacing the panel.
Old April 10th, 2009, 03:10 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
dry ice? interesting.
Old April 10th, 2009, 04:42 PM
specops1526's Avatar
specops1526
Beluga '97 90
When I first got my truck I had some guy come and push the dings out. Probably similar to Dent wizard. Came out good. I'd try that first before bondo.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 12th, 2009, 09:48 PM
hamiamham
mike
97 D-90
search "bondo" on this board. i seem to remember someone (recently) saying bondo and aluminum body panels are a no-go.
Old April 12th, 2009, 10:40 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Bondo is fine with AL. But if you can avoid repainting, do that first.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 12th, 2009, 10:47 PM
Bondo cracks from the flexing of aluminium. A very light skim of the stuff that is designed for alum is ok per Mike at ECR and others, but I have seen too many with shitty bondo that has cracked.
Old April 12th, 2009, 11:48 PM
I don't know if it works on aluminum, but there is some sort of lead filler they use as well instead of bindo that is supposed to be better. Pictures I saw of it looked like soldering it on.
Old April 13th, 2009, 01:20 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Best thing you can use is Devcon Liquid Aluminum. I used it on my hood. Acts like AL when it dries.. Total bitch to sand down and costs a lot. Bondo is fine though.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 13th, 2009, 06:45 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have heard the Evercoat filler is designed to be used on aluminum, but I have never used it.
I will try and use as very little as possible if any, and try the dry ice methode and a dent expert on the worst places. The ST doors have the most dent's so this is were I will try the filler,..anyway my long term ideas was to eventualy replace them with new units (the steel frames are badly rusted)..
Old April 13th, 2009, 08:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I second this... You can use it to fix small imperfections but large damage needs to be straightened or the panel replaced.. Sometimes a new panel might even need a dab if filler here or there...
Legend in My Own Mind.
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
