Bolts for fiberglass top - Defender Source
Old May 1st, 2014, 07:55 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Bought a ST that comes with a fiberglass top. Some of the bolts are missing. Is there a kit I can buy to replace? Thanks.
Old May 1st, 2014, 08:57 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
FT sux but I have some hardware............no kits available that I know of!!!!
Todd
'95 D90 #2206
'66 109" P/U
Old May 1st, 2014, 10:52 PM
From what I remember, they aren't anything special. You should be able to get stainless replacements at a hardware store.
Old May 1st, 2014, 11:34 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Bolts can be found most stainless steel section of hardware store, trick is the washers. I ended up having some square ones punched out of stainless local fab shop. Easy enough w Scotchman or something similar, hard part convincing shop to due handful of them
Old May 1st, 2014, 11:40 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
I remember using square washers on mine too. I think to fit inside the rain gutters but still be big enough for the bolt? Probably more of a rectangular shape washer than square. Was able to source mine from a local hardware store. Nylon lock nuts on bottom. Use waterproof silicone sealant in the seams around the area where the top meets the front windshield frame.
Old May 1st, 2014, 11:46 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Yep rectangular and good advice w silicone as well, forever dripping. If get really hung up pm me as I probably have some left over in one the boxes.
Old May 2nd, 2014, 10:24 AM
Eric_S
Eric
'97 D-90 ST #1507
I use rope caulk (also called cord weatherstrip or strip caulk) instead of silicone. It has the consistency of play-dough or modeling clay but does not harden. It's much easier to remove and apply. I put it on the bolts along the top of the windshield and the bolts where the top meet the side panels. It has the added benefit of acting like a cushion between the bolts and fiberglass top.
Old May 5th, 2014, 11:43 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
All great stuff guys. Thank you very much.
bolts, fiber, fiberglass, fiberglass top, glass, top
Rear side windows: interchange between SW top and fiberglass top? jaherring Defender Technical Discussions 14 January 10th, 2009 10:55 PM
Badger Top Wanted! Will Swap For Fiberglass Top AJKing Wanted 0 October 4th, 2008 11:30 PM
Rear Top window on D-90 fiberglass top ttrover Defender Technical Discussions 7 November 9th, 2006 09:57 AM
Fiberglass top for Soft Top? boshea Wanted 1 April 20th, 2004 04:53 PM
Fiberglass top for Soft Top? boshea For Sale - Parts 1 April 19th, 2004 04:23 PM
