Bolts for 110 plastic fuel tank cradle - Defender Source
Old April 11th, 2011, 08:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Not sure if these are 8mm or 10mm?
I have the 8mm riv-nuts but if they are 10's i don't want to skimp and lose my tank. I mean the 2 that go to the rear cross member and the 2 that bolt through the cross member just in-front of it.
thanks
Old April 11th, 2011, 09:06 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I think I used 3/8 grade 8's.
Land Rover 110
Old April 12th, 2011, 03:01 AM
TS888's Avatar
TS888
Tony Sims
1984 110
The rears are 8mm, the fronts are 10mm without captive nuts.
Tony
1984 110 "Smokey" (sold)
Old April 12th, 2011, 06:04 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
my front bolts seemed to have rivnuts in the frame
Old April 12th, 2011, 06:56 AM
Capt Milks's Avatar
Capt Milks
Your was a Td5 right? I had to install my riv nuts into my frame as it was set up for the metal 300 tank and had the bracket in the front. I switched over to the newer version plastic tank. So it makes sense that your riv nuts were already there.
Land Rover 110
Old April 12th, 2011, 07:03 AM
TS888's Avatar
TS888
Tony Sims
1984 110
There's a clip that holds the front bolts in situ (often assisted by a sh*tload of rust), but maybe on later frames the went to welded nuts. I'm skeptical though, that would be tantamount to an engineering improvement.
Tony
110, bolts, fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Slick Rock fuel tank cradle rvrsrvc Wanted 1 August 10th, 2005 09:48 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
