bolts are breaking! - Defender Source
Old January 20th, 2009, 05:29 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
bolts are breaking!
I am trying to replace the gas tank cradle, as the one that is on my rig is completely rusted through. I have been soaking the bolts for several days in WD40, but they are still sheering off! (!@#$!%@$) I have seen the "extractors" at sears, will those work? I have heard mixed reviews on them, and wanted your expert opinions before I make the purchase...
Would a good impact wrench get them out with out breaking them? (kinda too late for that, but worth asking...)
Old January 20th, 2009, 05:35 PM
Phil,
I would soak them in PB Blaster... WD 40 is really a water dryer and very mild lubricant. The bolt extractors will work, but will take a good bit of patience too.
Old January 20th, 2009, 05:38 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
so I should use the PB Blaster, and then use the extractors? What kind of extractors should I use? Is there a specific brand that is better then the ones that I saw at Sears?
Old January 20th, 2009, 05:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
I hope you don't have a lot of gas in your truck. It makes it more of a pain. Make sure you replace all the bolts with stainless and hopfully you bought either a stainless or galv new cradle.
Old January 20th, 2009, 05:47 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I had one break off on the inside of the crossmember. I ended up having to weld a nut on the back side where the threads were exposed and backed it out of the hole. If you have that capability, then it's not too hard.
And yes, empty the tank!
Semper Fi!
Old January 20th, 2009, 05:53 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Usually yes, but I used an impact on mine and STILL broke 5 out of 6.
Old January 20th, 2009, 06:06 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Got a galvanized one, so that will be nice if I ever get it on there! Has about 1/2 tank in it, so i am thinking I need to strap the tank up so that it doesn't drop out... any suggestions other then that?
Is this the extractor kit that I would need?
http://www.amazon.com/Drill-Out-Powe...2492680&sr=1-9
Old January 20th, 2009, 06:18 PM
x2 on the PB.
Old January 20th, 2009, 06:24 PM
snurp
Keith Kuboske
94 D90 ST Arles Blue
I second the pb blaster...just replaced my gas tank guard yesterday and only broke one bolt. My guard was so far gone that it fell apart. I replaced with one from southdown as I have done with my prevoud D-90 and DiscoII. They come with stainless bolts to replace the POS rovers parts. Also make sure low on fuel.
Keith K.
94 D90 ST White
02 Disco II
Old January 20th, 2009, 07:22 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Low fuel, PB Blaster are the way to go, soak with PB and loosen a bit, then tighten/loosen again... use this process till you get them out.
A ratchet type hold down strap works great to support the tank.
If broken tap and drill them out,...yes weld on a nut and use this to remove the broken ones.
Old January 20th, 2009, 09:27 PM
huck1974's Avatar
huck1974
shane cates
94 d90
get used to breaking bolts. Wait till you snap off half the collector studs.
And hay
And I love you too
Old January 21st, 2009, 12:04 PM
c2sox's Avatar
c2sox
Al Cruz
93 110 #428 and 01 Disco SD7
Has anyone used Kroil? Just wondering if it's better than PB blaster.
Old January 21st, 2009, 07:22 PM
black diesel
Kyle Caskey
Yes it's better, probably the best. Schaeffer penetro is also really good.
Old January 22nd, 2009, 07:46 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Don't think that just replacing those bolts with stainless will be the cure. Stainless is not beyond corrosion (especially most of the offshore junk available today) and will snap off just as easily. If you don't put anti seize on whatever you put in, your just wasting money.
Kroil makes PB blaster obsolete.
Matt Browne
Old January 22nd, 2009, 05:38 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
The reason they break off (at least why mine did, anyway) is dirt/grit that gets on the exposed threads. When you then try to unbolt them, the grit gets wedged into the small gaps in the threads, effectively locking the bolt in place. Apply enough torque and the heads will shear off, because you're not gonna be able to force those grit-embedded threads through the whole way.
The prevention for this is the thoroughly clean the exposed thread of all dirt and grit, before starting to unscrew them. This is relatively easy to do on the front bolts (at least is was on mine). The rears are inaccessible without a bunch of disassembly; so I broke one of mine. It was wedged in so good that using extractors only succeeded in breaking the extractor. That's a real mess, since now you're dealing with hardened steel that cannot be drilled with normal drill bits. My solution was to use a Dremel to make a dimple in the center of the remaining piece (I used a carbide bit to grind out the broken piece of the extractor). I then used left-hand drill bits to drill it out; I kept going up in size until it started moving. It was wedged in so well I ended up using a drill bit that was almost equal to the minor diameter of the bolt.
Old January 22nd, 2009, 06:23 PM
Or you know, cut off the offending captive nut and weld on a new one.
Old January 22nd, 2009, 06:25 PM
CDeWan
Clay DeWan
5.3L beastie
it is good to know that I am not the only one who swore and had a fit when mine broke. I think I may have drilled new holes and used nuts and bolts where I could rather that continue to screw with the brooken ones.
bolts
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Stainless window bolts Peter Defender Technical Discussions 1 July 6th, 2004 10:44 AM
» Defender Registry
Mis-fit
Jpayne
Ezra
REDrum
Add your Defender
