bolting 200Tdi to LT77 question - Defender Source
Old September 11th, 2009, 01:54 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
installed the 200Tdi into my 1983 110 with the LT77 trans...there are now about 4 empty bellhousing holes...what goes in there?
is it studs or bolts/nuts?
thanks
George
Old September 11th, 2009, 04:11 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If there corresponding holes in the flywheel housing, then either is okay. If no corresponding holes in flywheel housing, you can drill and tap and again use either. I have four bolts, in the bottom four holes and studs/nuts for the rest
Old September 11th, 2009, 04:23 PM
I am told early LT77s used studs but the NAS 110s ones I have seen used bolts.
Old September 11th, 2009, 04:36 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Bolts would would be fine and are easiest/cheapest unless you have some appropriate studs laying around
Old September 11th, 2009, 04:37 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
This is what mine looked like.
ID:	21437   Click image for larger version
Old September 11th, 2009, 06:24 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
When I took my 2.5TD out, it had mostly studs, with some bolts and some just missing... I went with all studs when I put the 200TDI in. I think there was one blank hole on the engine that I had to drill and tap for a stud.
Old September 11th, 2009, 07:58 PM
What engine was in there before? I just did too 200TDI swaps and all the holes were filled...
Old September 11th, 2009, 08:11 PM
Gkase's Avatar
Gkase
George Kase
there was a 2.25 5 main petrol in there...don't know why it ended up with empty holes...but will dig up some bolts to fit I guess...any particular kind?
Old September 12th, 2009, 12:18 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Using studs vs bolts means fewer seized fasteners with time. It is a common fix to put studs in for the front timing cover as well or eventually you end up breaking off a bolt when changing the belt...
Old September 12th, 2009, 12:23 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
George,
first shot is of the 2.5 TD when it came out - not sure there were enough there to hold it. The next shots are of the blank hole in the 200TDI that I drilled and tapped. I used one of the studs from the 2.5, but it's a standard metric stud (M10 I believe) that I have bought at the local hardware store before. Final shot is of the 200 before I put it in.
Name:	Engine Conversion 020.jpg
ID:	21441   Click image for larger version
Name:	Engine Conversion 028.jpg
Name:	Engine Conversion 029.jpg
ID:	21443   Click image for larger version
Name:	Engine Conversion 030.jpg
Name:	Engine Conversion 032.jpg
200tdi, tdi
200Tdi and LT230 Gear Ratio Question newfD90 Defender Technical Discussions 33 June 1st, 2016 02:30 PM
Alternator wiring question 2.5 NAD to 200tdi dave_lucas Defender Technical Discussions 6 December 3rd, 2009 12:01 PM
LT77 & LT230 from 200TDI ajh For Sale - Parts 5 July 23rd, 2009 01:44 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
