Bolt Sizes - Defender Source
Old November 21st, 2012, 07:46 PM
Bolt Sizes
Took this from discoweb. I looked around on D90 but couldn't find the equivalent information. Thought it would be convenient to put here locally. Sorry if this is already covered somewhere on the forums.
Land Rover Discovery 1 Fasteners
Michael Kronmal (mkronmal@yahoo.com)
Qty Size Pitch Length/Type Location
2 M14 2.0 80mm Panhard Rod
2 M14 2.0 Locknut Panhard Rod
4 M16 2.0 100mm Front Radius Arm to Axle
4 M16 2.0 Locknut Front Radius Arm to Axle
2 M20 2.5 Nylock Front Radius Arm to Frame
2 M20 - Washer Front Radius Arm to Frame
2 M20 - Dished Washer Front Radius Arm to Frame
2 M20 2.5 Nylock Rear Link to Frame
2 M20 - Washer Rear Link to Frame
2 5/8 11 4in Rear Link to Axle
2 5/8 11 Nyloc Rear Link to Axle
6 M10 1.5 30mm Rear Link Bushing Plate
6 M10 1.5 Nylock Rear Link Bushing Plate
8 5/16 24 nuts Shock Towers
8 5/16 - lock washer Shock Towers
2 5/16 24 1in Rear Link Balljoint
2 5/16 - lock washer Rear Link Balljoint
4 M10 1.5 35mm Front Rollbar
4 M10 - Washer Front Rollbar
4 M10 1.5 Nyloc Front Rollbar
4 M10 1.5 35mm Rear Rollbar
4 M10 - Washer Rear Rollbar
4 M10 1.5 Nyloc Rear Rollbar
2 3/4 16 4in Top Link
2 3/4 16 Nyloc Top Link
4 M10 1.5 35mm Front Shock Mount
4 M10 - Washer Front Shock Mount
4 M10 1.5 Nyloc Front Shock Mount
6 M10 1.5 110mm Rear Upper Shock Mount
6 M10 - Washer Rear Upper Shock Mount
6 M10 1.5 Nyloc Rear Upper Shock Mount
8 M12 1.75 Front and Rear Sway Bar Mounts
8 M12 1.75 Nyloc Front and Rear Sway Bar Mounts
20 M10 1.5 40mm Axle Flanges
6 M8 30mm Water Pump
16 3/8 24 Nylock Propshaft (front and rear) ends
8 3/8 24 1.25in Propshaft (front and rear) diff end
4 3/8 24 1.25in Propshaft (front) transfer case end
20 M10 1.5 Nut Differentials
Engine
6 7/16 14 96mm Cylinder Head
14 7/16 14 66mm Cylinder Head
8 3/8 UNC 2.79in Rocker Shaft Pedestals
2 M4 0.7 14mm Stepper Motor (IAC)
2 M4 0.7 Potentiometer
3 1/4 UNC 1in Plenum Water Jacket
1 1/4 UNC 1-3/8in Plenum Water Jacket
1 M8 80mm Plenum Chamber
5 M8 55mm Plenum Chamber
6 M8 - washer Plenum Chamber
1 7/16 UNC 1-1/8in camshaft
2 5/16 UNC 3/4in camshaft retaining plate
5 5/16 UNC 3-1/8in Front Cover
1 5/16 UNC 3-7/8in Front Cover
3 5/16 UNC 4-3/4in Front Cover
9 5/16 - washer Front Cover
8 1/4 - lock washer Valve Cover Bolts
8 1/4 - washer Valve Cover Bolts
4 1/4 20 1-5/16in Valve Cover Bolts
4 1/4 20 7/8in Valve Cover Bolts
6 M8 1.25 40mm Exhaust flanges
6 M8 1.25 Prevailing Torque Locknut
M8 12mm Crankshaft Pully
16 3/8 16 1" or 2"? Exhaust Manifold to Heads
2 M4 15mm TPS
Use grade 10.9 for all metric
Use grade 8 for all SAE
Old November 21st, 2012, 08:01 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Might be an idea to combine this with the stainless hardware .pdf I posted and add the McMaster Carr part numbers. Thanks for sharing this!
Old November 21st, 2012, 08:15 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I have found from working on my '94 NAS that you should have a reality check before defaulting to lists like this as many bolts are actually SAE, particularly in the suspension.
Old November 22nd, 2012, 09:01 AM
Old November 24th, 2012, 02:57 PM
Along these lines anyone know the bolt sizes that hold the fuel tank skid on a NAS 90? Got an aluminum skid but still have the rusty ass old hardware.
Old November 25th, 2012, 07:46 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Pretty sure they are M10. When I was doing things like my rear skid and other misc bits I found it very useful to just pick up one of the multi bolt packs that had a variety of lengths in bolts ranging from M4-M12.
Old November 25th, 2012, 09:09 AM
I've still got some 50mm M10s, but prob too long we'll see. These multipacks of which you speak....McMaster?
Roll cage Torx bolt sizes mwmorgan22 Defender Technical Discussions 7 December 17th, 2008 08:31 AM
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
» Defender Registry
110
Rugbier
SW 2267
ramskull
Add your Defender
