Bolt size - R380 to 3.9l? - Defender Source
Old March 9th, 2015, 01:03 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
This R380 and the 3.9l were not attached when I sourced them so I don't have the original bolts between the two. I am getting ready to put the 3.9l on an engine stand and I thought I needed 3/8" bolts...but acouple just won't fit. Almost seems like there are two different bolt sizes going into he 3.9l. Is this right or am I dealing with some mangled threads?
ID:	115610   Click image for larger version
"I think we are good...its still dripping"
Old March 9th, 2015, 07:18 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I can check tonight when I get home but I think they are m10x150
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old March 9th, 2015, 07:50 AM
lordhelemt's Avatar
lordhelemt
Paul
Second thought I think those are m8 1.25
Old March 9th, 2015, 09:46 AM
WildBoar's Avatar
WildBoar
Derek Borror
Many thanks...of course metric.....and I bet you are correct about the m8 1.25. The m10 1.25 I tried to fit wasn't going to work at all.
Old March 9th, 2015, 11:55 AM
WildBoar's Avatar
WildBoar
Derek Borror
Ugh....m8 1.25 is loose and doesn't tighten down. I may have a slight issue....as 3/8 really fits (without forcing it) in two of the holes. And the other holes' threads look to be the same as 3/8 16 but slightly smaller. I am assuming all these are supposed to be the same, right?
Old March 9th, 2015, 12:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
3/8th x 2" UNC
Old March 9th, 2015, 12:47 PM
WildBoar's Avatar
WildBoar
Derek Borror
So that is what they are supposed to be? Or tap them so they are all that size?
Originally Posted by Z.G View Post
3/8th x 2" UNC
Old March 9th, 2015, 12:49 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The book calls for 8 of them in that size
Old March 9th, 2015, 12:57 PM
WildBoar's Avatar
WildBoar
Derek Borror
Hmmm....ok. Wonder what I have going on here then. It really looks like a 16 thread as well.
Looks like I just need to add a little force to see what happens.
Thanks!
Old March 9th, 2015, 04:34 PM
cant hurt to clean out the hole and run a tap through it.
Old March 9th, 2015, 06:46 PM
lordhelemt's Avatar
lordhelemt
Paul
Whatever Zach said. He provided one for me that I snapped off in the block. Yes, i'd run a tap in there to clean out the years of gunk.
Old March 9th, 2015, 06:55 PM
WildBoar's Avatar
WildBoar
Derek Borror
I think that will be the remedy. Thanks.
Old March 9th, 2015, 11:54 PM
WildBoar's Avatar
WildBoar
Derek Borror
Cleaned out 3 mud dauber nests and tapped the rest. 3/8 16 thread bolts work perfectly. Thanks all!
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
check a bolt size-please mattdh Defender Technical Discussions 0 April 5th, 2004 07:00 PM
bolt size for bonnet hinge Campbell Defender Technical Discussions 1 November 7th, 2003 10:41 AM
