Bolt size for Radius Arms and Rear trailing arms - Defender Source
Old May 28th, 2009, 09:23 PM
Rugbier's Avatar
Rugbier
Gustavo
Do you have the size for the bolts that attach the radius arms to the axle ( through the busing ) as well as the ones for the Rear trailing arms
Does 5/8 3.5" for the front and 4" for the rear sounds like it?
NO SIGNATURE
Old May 28th, 2009, 09:41 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
They are 16mm technically but 5/8 is just fine. The lenth sounds right. I can take a measure if you want.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 28th, 2009, 09:46 PM
Rugbier's Avatar
Rugbier
Gustavo
Thanks for the info, no don't go into any trouble meassuring, worse case scenario I will have some extra bolts.
I assume GRADE 8? zinc? SS?
Are they thraded through or they have like 2" of smooth area?
Thanks again
NO SIGNATURE
Old May 28th, 2009, 11:13 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks again
No worries. They are plain shanked as the lenth dictates. Definitely grade 8. If you go to True Value or similar store you can get the pretty Zinc grade 8 bolts. I think nylocks are a nice upgrade too while your at it. New washers don't hurt either.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 29th, 2009, 12:44 AM
Why not use factory bolts? I am sure roverguy or someone else who parts things out will have a set laying around for cheap.
Old May 29th, 2009, 10:23 AM
Rugbier's Avatar
Rugbier
Gustavo
I am putting new radius and new trailing arms with new poly bushes, I am trying to avoid re-using old stuff. called the dealer and their prices are like 16.00 per bolt/nut
NO SIGNATURE
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Rear Trailing Arms Joe P Defender Technical Discussions 7 July 16th, 2005 11:36 AM
Jay Geaney chrisvonc Defender Owners 0 July 2nd, 2004 01:32 PM
Cliff Durrett chrisvonc Defender Owners 0 March 14th, 2004 10:06 AM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
