Bolt size for Diff? - Defender Source
Old July 3rd, 2005, 01:46 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Bolt size for Diff?
I am installing QT diff guards with safari gard rock gard. My problem is that bolts are not long enough for the both of them. I went to Lowe's to some longer bolts. The bolt size I thought would match up the best was a 10 / 1.25, that didnt work. So, what is the correct size for the two bolt the back and bottom of the diff?
David
Old July 3rd, 2005, 03:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I'm not sure the exact thread...I know that they are British standard...3/8 x 20 maybe...I've never been able ro find replacements. For repairs or accessory mounting I usually drill the holes oversize and tap to 7/16 UNF.
Rob
Old July 4th, 2005, 02:02 AM
m.olivares's Avatar
m.olivares
marc olivares
3/8-20 and you'll find them here
Old July 5th, 2005, 08:28 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Tap it to 7/16 like Rob said. I do not even drill before tapping it the larger size, but I am pendy.
The larger bolt with coarser threads will suit your needs better.
JP
legend in my own mind
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
bolt size for bonnet hinge Campbell Defender Technical Discussions 1 November 7th, 2003 10:41 AM
