Bolt Size - Defender Source
Old September 13th, 2015, 01:39 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Bolt Size
# 18 in this picture.
Cant find a single diagram with a p/n or a size for this bolt (there are 2)
Out of a disco but should be the same as defenders.
edit also thread pitch. My chart only goes up to M12, I'm thinking this is m13-20
Old September 13th, 2015, 01:58 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Going off memory I believe it is 1/2" x 6.5" - but I could be off by a little bit. Make sure to antiseize the shit out of the new bolts!
Old September 13th, 2015, 02:03 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
That's what microcat says as well and I just replaced mine based on those dimensions.
bossman429's Avatar
bossman429
Adrian
1988 90
OK - i couldn't seem to get it to thread onto a 1/2-20 nut but the threads may be jacked from hammering it out.
I'll try cleaning them up and try again.
Thanks don! Glad its standard.... makes life easier to get a new one!
Old September 13th, 2015, 02:19 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Could it be coarse thread, 1/2"-13?
Old September 13th, 2015, 03:51 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok. Pretty sure it's 1/2-20 and just the first few threads are jacked up
Thanks again don
Old September 13th, 2015, 03:52 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I am sure you could do 13tpi but I believe stock is 20tpi fine thread. I would do fine thread if you had the choice.
------ Follow up post added September 13th, 2015 03:54 PM ------
Originally Posted by bossman429 View Post
OK - i couldn't seem to get it to thread onto a 1/2-20 nut but the threads may be jacked from hammering it out. I'll try cleaning them up and try again. Thanks don! Glad its standard.... makes life easier to get a new one!
Those fine threads get effed up easy - it could have been replaced by an M12/M13 at some point? I can check and see what I have for bolts in the garage if you want?
Old September 13th, 2015, 04:38 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Interesting article
http://www.bestbolt.com/white_papers/white_paper_08.pdf
Really not many reasons to use fine thread
Don't worry about it Don I'll just grab something from HD or thompsons down the road.
Old September 13th, 2015, 05:25 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Interesting article http://www.bestbolt.com/white_papers/white_paper_08.pdf Really not many reasons to use fine thread Don't worry about it Don I'll just grab something from HD or thompsons down the road.
Interesting article - agree with what they say.
I just thought that fine thread would hold its tightness better/longer in that application. Thought that is why they used fine thread for shock absorbers.
------ Follow up post added September 13th, 2015 05:29 PM ------
And Thompson will have something that will work - can't believe the stuff that guy has!
Old September 13th, 2015, 06:32 PM
In this application you want fine thread. You want the clamping pressure to provide the shear strength so that that bolts are not shear loaded. The fine thread makes it easier to ensure proper clamping force.
Old September 13th, 2015, 06:33 PM
down_shift's Avatar
down_shift
Russell
Look for a Tractor Supply if one nearby. They have loads of zinc treated Grade 8 hardware. That or McMaster-Carr with their good app and fast shipping. No such luck at HD, other than their selection of garbage.
ID:	129699   Click image for larger version
Make sure you are getting grade 8. Not bolts you need breaking in an emergency stop on the highway.
Old September 13th, 2015, 07:31 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Not really following you on the first one...From what i read the only advantage fine thread has is tensile strength (pulling the bolt apart literally from opposite ends). Wouldn't Shear strength depend on the material and thickness (example 1/2" grade 8 vs 3/8 grade 5) I understand if you were putting the shear load at the thread then coarse thread could be less (deeper thread cuts) but a proper sized bolt will have the shank at any shear point, not the threaded portion.
but yes, I'm going to use grade 8 yellow zinc on all hardware (that i can) on this build.
Probably overkill for many applications but rather safe than sorry. Also i found the yellow zinc plated holds up best to the elements.
McMaster Carr kills you on shipping and is often pricey. i think i may put together a list of all I need and try bolt depot out on a few orders.
Old September 13th, 2015, 08:14 PM
Are you in a hurry? I may have extras of these from doing mine - since you usually have to buy in quantities from mcmaster. I could look tomorrow evening.
Originally Posted by pendy
I'm here for the D's
Old September 13th, 2015, 08:22 PM
bossman429's Avatar
bossman429
Adrian
1988 90
No hurry at all. Don't even have the pcs back from coating yet
You can buy these 1 at a time since they are larger. But honestly it's nothing for me to purchase. Just wanted to make sure I had the right size since one twisted and broke taking it off and the other was banged up from removing it
Old September 13th, 2015, 08:24 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I got those bolts from the local Fastenal; might have had to wait a day or 2 to get them.
As someone else said, coat the entire bolt liberally with silver grease!
Rent my
Old September 13th, 2015, 08:31 PM
If you are replacing them, the only things that matter are
grade
outer diameter
length including proper shoulder length
iic correctly the 3 are not all the same shoulder length.
You can choose whatever thread you like since you'll be buying new nuts too
Old September 13th, 2015, 08:45 PM
bossman429's Avatar
bossman429
Adrian
1988 90
If you are replacing them, the only things that matter are grade outer diameter length including proper shoulder length iic correctly the 3 are not all the same shoulder length. You can choose whatever thread you like since you'll be buying new nuts too
3? Only 2 bolts. Typo?
Old September 13th, 2015, 10:35 PM
My bad - I read 8 earlier, not 18. Yeah pretty sure I don't have those left over sorry.
Old September 13th, 2015, 10:41 PM
When you clamp two things like this the idea is to tighten the bolts to proof. The way the clamping works, as you load the joint there is no change in the load on the bolts. In this case the bolts stay in pure tension and the shear load is only between the clamped parts. A fine thread bolt will provide better and more reliable tension due to the way the bolt tightens.
The engineers that designed the joint choose fine thread for this reason. Normal bolts are metric coarse on a Defender. They use UNF when there is a valid engineering reason.
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
check a bolt size-please mattdh Defender Technical Discussions 0 April 5th, 2004 07:00 PM
bolt size for bonnet hinge Campbell Defender Technical Discussions 1 November 7th, 2003 10:41 AM
