Bolt question - Defender Source
Old March 13th, 2015, 10:52 AM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Bolt question
This is probably a stupid question, but does anyone know what size bolt is needed to secure the female portion of the rear bench seat belt, to the floor. My truck came with a belt and no bolt? Also is there a place to look up bolt sizes? I keep having to replace old ones and trial and error is a PIA.
ID:	115983   Click image for larger version
Old March 13th, 2015, 11:01 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Not sure on the size, but if it's the same as a RRC I should have a couple laying around with spacers…. if you can't find them locally.
Old March 13th, 2015, 11:03 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Should be 7/16 UNF.
-Ash
Geared Restoration Co.
352-572-3236
Old March 13th, 2015, 09:08 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
the seatbelt bolts are, as Ash mentioned, 7/16-20 but that might just have been a regular bolt in the floor. If so use a grade 8 bolt.
Old March 14th, 2015, 02:46 PM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Thanks a ton, if I have any problem acquiring one, I will let you know. Much appreciated
------ Follow up post added March 14th, 2015 02:48 PM ------
Thanks for the help you guys
Old March 28th, 2015, 10:49 AM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Just wanted to say thanks for help. Seat belt installed
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
Bolt Question Buckon37s Defender Technical Discussions 5 January 30th, 2007 08:28 PM
Replacement Bolt Question ronward Defender Technical Discussions 4 January 12th, 2006 09:30 AM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
