Bolt lenght on drive flange to hub - Defender Source
Old June 21st, 2014, 10:10 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ones anyone have a length of the 10mm bolts that secure the front drive flange to the actual hub assembly? I thought they were 50mm but that is too long. Maybe 40 or 45mm? Not sure if anyone have an axle lying around to measure this for me.
Legend in My Own Mind.
Old June 21st, 2014, 10:17 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
That's weird. This says 50 as well.
http://allbrit.de/UNI.cfm?PAGE=755214&SPRACHE=EN
Old June 21st, 2014, 10:33 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I think that length is for the older thicker flange like on the 110
Old June 21st, 2014, 10:35 AM
Broncoduecer
peter
D90
Yea. The newer one says 45.
http://allbrit.de/UNI.cfm?PAGE=755193&SPRACHE=EN
Old June 21st, 2014, 10:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Great. Thanks for quick response
------ Follow up post added June 21st, 2014 10:48 AM ------
Great. Thanks.
Old June 21st, 2014, 12:01 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
For the thicker flanges yes its 50mm, but its not so much the length of bolt the shoulder of the bolt needs to enter into the hub by a couple of mm, if you check the hub you'll see the hole is tapered for that. I have three different sets of bolts that I bought and all the shoulder lengths are different.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 21st, 2014, 01:24 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will check that for sure
Drive flange, swivel housing? hub? o2batsea Wanted 0 June 4th, 2012 09:42 AM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
Drive flange bolt sirjond Defender Technical Discussions 5 November 16th, 2010 01:36 PM
Muffler Flange Bolt removal Bozman Defender Technical Discussions 2 May 28th, 2009 06:43 PM
Drive flange bolts KevinNY Defender Technical Discussions 6 January 3rd, 2007 10:31 PM
