bolt head size?(wrench size) - Defender Source
Old October 7th, 2004, 12:05 AM
mattdh's Avatar
mattdh
Matt Hurst
if you open your door and look down at the seat box lip, there are 4 bolts in the box lip with 2 of the bolts going in to the seat belt bracket.i need to know what size bolt those are?are they all the same--- size-6mm(that would be a wrench size of 10mm) or-- 8mm(wrench 13mm)also the head size of the bolt going into the top back part of the seat belt bracket and the bolt above that one?and one last bolt size-the bolt that goes in to the seat box lip and the floor panel (if you are seating in the driver seat it would be behind you right heel and the floor panel has a cut out around in a u shape it is also the same on the pass. side but it would be behind the pass.left heel) thanks for the help
Old October 7th, 2004, 09:51 AM
mattdh's Avatar
mattdh
Matt Hurst
i am not asking any one to take these bolts out-just need to know what size wrench-then i can figure out the bolt size
Old October 7th, 2004, 10:45 AM
10mm heads or 6mm bolt.
On the lower bracket? Those are 10mm heads or 6mm bolts.
Same again, 10mm heads or 6mm bolt. I would have replied sooner but I had to wait for a break here at work.
Old October 7th, 2004, 05:55 PM
mattdh's Avatar
mattdh
Matt Hurst
thanks again mike-you are all ways a big help
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
