Bolt & nut size? - Defender Source
Old June 2nd, 2004, 05:50 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Bolt & nut size?
Do any of you rebuilders know the size type & grade of bolt (inc. nylok nut) that attaches the bulkhead (firewall) to the chassis outrigger?
Thanks in advance.
Sniff my Diff ;)
Old June 2nd, 2004, 10:46 AM
mattdh's Avatar
mattdh
Matt Hurst
brett- they are grade 10.9 size 12mm x 170 mm regular course thread, it didnt have a lock nut on it just washer and lock washer set up.i could probably tell you the size of every bolt on the defender,i have become a bolt expert after starting my project.
Old June 2nd, 2004, 02:23 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Hey Matt - Do you know offhand the grade/size of the panhard rod bolt (steering box side) and radius arm bolts (axle end)? Thanks.
Old June 2nd, 2004, 05:32 PM
mattdh's Avatar
mattdh
Matt Hurst
panhard rod 8.8 14mmx80mm radius arm 8.8 16mmx100mm
Old June 2nd, 2004, 06:03 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hi Matt,
While you are at it
Do you happen to know what size/grade the 4 bolts that hold the sway bar to the gas tank skid plate are?
Dave
Old June 2nd, 2004, 06:40 PM
mattdh's Avatar
mattdh
Matt Hurst
dave hows it going? thats the least i could do for you -i owe you big!!! i dont have those bolts any more but they would be a grade 8.8 and 8mm- length i am not sure but my guess is 20mm would be about the right size
Old June 2nd, 2004, 07:21 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Matt - Thanks very much for the info. Gotta get me some longer bolts since the ones that are in there are too short.
Old June 3rd, 2004, 06:26 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Excellent!
Thanks Matt, you are the bolt Daddy!
Mine has got a Nylok, not lockwashers. I must say I prefer Nyloks.
Sniff my Diff ;)
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
What size is the a-arm bolt? cbass Defender Technical Discussions 9 August 22nd, 2005 11:59 AM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
