bollocks - Defender Source
Old May 13th, 2011, 01:06 AM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Unhappy bollocks
excuse my french, but that was the exact phrase i muttered as i turned the key in rear door only to find it snap right off.
while on the bright side, it does perfectly match the other snapped of key i have, i would like to be able to open my doors again
so two questions for the landy guru's on d90-source:
1. can take the key stub with the number printed on it and get one made from a landy dealer using the code?
2. any tips on removing a key stem from a lock?
Old May 13th, 2011, 07:43 AM
LRover's Avatar
LRover
J. Michael McCaig
You should still be able to get a key/key code from the dealer. I have had good luck removing broken keys from locks using a staightened out small paper clip with a bit of a hook on the end. Use it to snag the top part of the key.
Old May 13th, 2011, 11:58 AM
To remove a broken key I use a broken off end of a jewelers' saw blade.
Old May 13th, 2011, 02:53 PM
brettm's Avatar
brettm
Brett
thanks for the tips... i tried the paperclip approach, but failed dismally... will give a jeweler saw a whirl, if no dice i guess i'll try and take the lock out and give it to a lock smith.
Old May 16th, 2011, 11:30 PM
brettm's Avatar
brettm
Brett
to close the thread:
i ended up taking the rear door apart and pulling the lock. i took it to Bulgers in Seattle for anyone that runs into this problem locally.... (http://www.bulgerlock.com/). For $30 they had the broken key out and a new key made from the fragments in no time. The originally quoted $160, but with the lock out it was much easier for them to work with.
Interestingly the new key is a Mazda blank... I ordered from steel defender body blanks from WCR and will get a better key made.
lesson learned.
Old May 16th, 2011, 11:44 PM
Pump the lock cylinder full of Wurth HS2000 lube.
