Body Work Question - Defender Source
Old October 5th, 2009, 01:41 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Question Body Work Question
Hello All,
I am new to the forums and have recently bought a 94 AA Yellow D90 (lovin it!)
I have a couple questions when it comes to bodywork...i have been talking to body shops and enthusiasts and they all seem to say things slightly different. I have a dent in the rear driver quarter and the usual small bubbling on the paint in the bottom of the doors and under the door s. The rest is pretty clean!
Some of things i have heard are as follows:
Ah, painting aluminum is like metal except different fillers and better prep (should be able to shape and pound it out).
Go to Body Shop that specializes in Aluminum...there is a body shop that does all the NSXs in town. They will be able to do it. NSXs???
Go to this other body shop they have spent a ton on having a special area for just aluminum work. (the most important thing is you dont want iron particles when spraying.)
Dont fix it, replace the panel (might not get the spot welds right though!)
Personally, i would just replace the tub. Replace the tub, really???
Etc...
If I am expecting to pay more, does anybody know how much more than regular body work (%) ?
Also, seems like they all say they cant guarantee any future bubbling in that area, even within 5 years.
Any existing threads, links or advice would be appreciated....
Thanks in advance.
Old October 5th, 2009, 01:46 PM
Personally, I would leave it as is (maybe tap it back close to right and rattle can it with some tower paint AA yellow spray can) or replace the tub. I have seen lots of bad body work on defenders and little good body work on them.
As far as the bubbling on the doors. YOu are basically screwed as it will keep doing it because it is from the galvanic corrosion between the steel door frame and the aluminium skin. It comes from the inside of the door to the outside. Again, leave it be or take the skin off the door, galvanize the door frame and put a new or repaired skin back on.
Old October 5th, 2009, 02:08 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I bet ECR could massage that out
Robert Deniro
Old October 5th, 2009, 02:10 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
Vancouver is a LONG way from ECR.....
Old October 5th, 2009, 02:12 PM
Neil McCauley
Neil McCauley
Actually a few years ago, someone kicked in the rear lower portion of my tub in my Series IIA while it was parked in the street and it was folded in enough to leave a crease. I hammered it out with a rubber mallet then used a flat piece of wood behind the crease and hammered it as straight as I could get it, you can still sorta tell but barely since the paint isn't gloss but moreso a drab faded finish. Still way better than it was. You can even use a little filler once it for the most part straight, just try to recreate the spot welds with the eraser end of a pencil on the bondo hehe
Neil
Robert Deniro
Old October 5th, 2009, 02:14 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
My 110 was damaged similarly and I took it to the local body shop and they did a bang up job knocking it back out and then putting a thin coat of body filler on there to smooth it out. I don't think it is a sin to have this done is cheap and easy and then you won't look at your truck every day feeling guilty.
The biggest problem with taking dents out of aluminium is that it work hardens and cracks very qucikly. You have to anneal it with a torch to get it to be maleable. I have tried it a few times and I can get it ok, but it is not like steel to work with.
Old October 5th, 2009, 02:18 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Thanks for the rattle can suggestion, i will have to get me some of that. (I will painting everything in my house to match the truck )
I guess i can add this option also...but, i think the rattle can repair on the rear quarter would drive me bonkers.
The corrosion bubbles on the door is super minor, i guess i can live with it...is their a way to slow it down or stop it?
The rear dent, is more of my concern...i have a rear quarter skin that came with the truck. looks like a bigger job doing this though than someone shaping it as close as possible then using some proper filer and paint. (maybe i am in aluminum denial)
I have a budget of about $3000...what would be the proper way to do it (skin, tub, shape it, fill it, rattle can it). also, anything i should tell the bodyshop or look for through the process.
Cheers,
Old October 5th, 2009, 02:23 PM
landrovered
S. Smith
$3K?????? My body shop charged me $700 for my repairs.
Old October 5th, 2009, 02:24 PM
3000 would buy you a perfect NAS D90 tub shipped to your door and if you waited around you could get it in yellow.
Spray waxyoyl between the frame and the skin to slow it down.
Seriously, a tab and rattle can could make that look pretty unnoticable. Much better than the inevitable cracked body filler look.
Old October 5th, 2009, 02:34 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Wow, i must be a slow typer...the time i was finished replying to t he first reply there was more. Great help guys!
Yeah, Looks like ECR does some nice stuff...i am a ways away.
Another roll of the dice option: There is a bodyshop here with a guy from Malaysia...who is chomping to work on it. He said this is all he worked on when he was back home. he seems to think he can pound it and use little too no filler.
I have had specialty cars my whole life but this is the first D90...can't believe how difficult this decision is...
I swore another vehicle would not consume me...
$3000, is Canadian funny money to you guys...everything here is more expensive and the dollar is worth less.
It's just a budget, want to do things right...but good to know it was $700.
Ok, new budget $2000...going to go D90 accessory shopping.
Old October 5th, 2009, 03:25 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
maybe JimC will post up his before and after pics; he dented his yellow 90 in a similar way and pounded it out. It is not perfect but much better than a caved in rear quarter and it didnt take much effort and I believe no money was involved.
Old October 5th, 2009, 03:42 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I had pretty much the same dent on mine, ponded it out and applied a thin coat of filler...looks great.
I really dont know long term on the fix as I just fixed it...I used "EverCoat" body filler, to me its the best on the market.
Old October 5th, 2009, 03:51 PM
Thanks for bringing that back up Tis! Anyway, I did in fact have the same damage, and I just sorta pushed & pounded it back into shape. Its still that way 2+ years on. Doesn't look great, but its a lot better than before and I can live with it until I have time to find a tub or find some other solution.
Old October 5th, 2009, 04:08 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
The story behind that story is what makes me laugh...sorry back on topic.
Old October 5th, 2009, 04:31 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Tim,
Connect with Jon Winningham on this board. He had a rear quarter replaced on his 110 and it looks great.
Matt
Old October 5th, 2009, 04:41 PM
Gibson04
Justin Church
1994 D90 / '04 Disco
Sorry to Hijack........Would you use acrylic or enamel for spotting in with a rattle can?
Old October 5th, 2009, 06:17 PM
Originally Posted by CDN90
Hello All,
I'm answering the only question I can.
Acura NSX's were aluminum chassis and body.
Old October 5th, 2009, 06:58 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Originally Posted by mattarm
Tim,
Matt
>>Thanks, i will for sure...
>>Story behind the Story...funny? Please Share!
>>Any before and after picks I know it's a bit to ask. Any Cracking? How long since it was repaired?
Thanks again Guys!
Old October 6th, 2009, 08:13 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I had similar damage the same spot on my AA Yellow 97 when I bought it. I had that taken care of along with re-doing the tops of the lower part of both doors where the door tops stripped off the paint down the metal and a nice ding where the wrap-around brush bar bent into the front quarter panel. They had to replace the flat rear panel but were able to save the side panel (you may not be as lucky - not sure).
The total was around 1700 and they did a killer job. Believe it or not I did it at the dealer (eeek!). Normally I never go there but I have to say I'm happy I did in my case for the body work. I may have been able to save a few hundred bucks but the thing looks mint all around and was professionally done. If I ever sell I have "official" paperwork on it. I priced it out at another shop and it was within a couple hundred bucks.
All that being said I don't take the truck there for maintenance or engine repairs!
body
Body Work in DC area????? Frankie Carbone Defender Technical Discussions 3 October 22nd, 2007 04:09 PM
Body work in Modesto area gofins Defender Technical Discussions 0 October 19th, 2007 06:24 PM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
