Body Transplant - Defender Source
Old November 23rd, 2007, 10:21 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Body Transplant
Does anyone know if I'll be able to swap the body from a 2007 onto a 1993 chassis?
Old November 23rd, 2007, 11:39 PM
Are you just going to mount the body or will you replace the motor too?
Old November 23rd, 2007, 11:41 PM
ajh
Andrew J. Hutton
I would have to start with the body, if I change the motor it will be to the new 4.5L Duramax or something similar later. Since the vehicle will still be registered as a 1993 I don't want to invalidate that.
body
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Body Panels and Work- Atlanta gtg067i Defender Technical Discussions 1 February 14th, 2005 05:03 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
