body repair - Defender Source
Old February 5th, 2014, 05:04 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
body repair
Going to repair my RHD side wings. Replacing (A) seems relatively straightforward, as it is bolt-on. (B) appears to be attached with a combination of rivets and spot welds.
(B) is available from suppliers by itself, or as part of an assembly that includes the top wing (C) (about $650).
I need to replace (B) because it is damaged but I can re-use (C). However, I understand spot-welding aluminum can be tricky.
Has anyone removed and replaced (B) only, and how hard is the repair?
If I don't want to mess with spot welding or riveting, should I just anneal and bang (B) back into shape?
I suppose I can buy an entire wing assembly but that seems expensive.
ID:	89213   Click image for larger version
Old February 5th, 2014, 05:07 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Eh...no more expensive than tearing it all down I would guess. How did you do that?
Old February 5th, 2014, 05:14 PM
CaptMidnite
Daniel Choi
Bought it like that last summer. Right now, I've got time and garage space so don't mind spending wrench time. I think (B) by itself can be found lightly used for $75.00
But (B) is throwing me for a loop because it is spot welded and riveted. I read up a fender wing repair article in LRO magazine where (B) was removed by drilling out the welds and rivets. The new piece was put back with adhesive and rivets but no welding.
Old February 5th, 2014, 05:20 PM
I have, it's not hard.
Unless you have a heat-treatment oven, you can't anneal aluminum. You can soften it for what is essentially hot forming, but it's not annealing. Also, unless you are an extremely good body worker, you will not succeed. I tried, I failed, I bought new panels, replaced everything, repainted everything.
How much is your time worth, and how good do you want the repair to look? Remember that you can find the individual pieces for a lot cheaper than it costs to buy the entire assembly.
Old February 5th, 2014, 05:28 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Where can we buy the whole assembled fenders? I've been buying bits and pieces from the usual sources for my D90 rebuild.
Robert Deniro
Old February 5th, 2014, 05:36 PM
Simmonites has the best prices I've seen thus far for the front/upper wing assembly. SP Land Rover is cheaper for other parts.
Old February 5th, 2014, 05:42 PM
CaptMidnite
Daniel Choi
Sonoronos, did you spot weld the aluminum?
Old February 5th, 2014, 05:47 PM
Those three assemblies are bolted together. You can get "B" as one piece. Banging "B" back to shape is hard as is it fairly complex with a bunch of parts. If you can get to a side, the alloy bangs back quite well. You will need some filler if you want it smooth.
Old February 5th, 2014, 05:51 PM
No, I did not spot weld. I riveted only. You can do the entire repair without spot welding except for one place.
Only one panel requires spot welding, and that is the "Inner wing valence". It's a small piece of aluminum and I used Panelbond on it instead.
I guess I could have riveted it on, but I didn't want the rivet to show in the final product.
Old February 5th, 2014, 05:53 PM
CaptMidnite
Daniel Choi
How easy is it to re-attach B to the fender assembly? I understand spot-welding aluminum isn't as easy as steel. Just use rivets and adhesive? Doing some research it seemes easier to order the whole fender assembly (I already have (A) panels)
Old February 5th, 2014, 06:27 PM
Couldn't you just pound out the dents?
Old February 5th, 2014, 06:41 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Yes you can, with a bag of sand and a large plastic mallet you can get most of that out. use caution as once you over work the alloy its very hard to shrink .
Lay the dented area on the sand bag and slowly go to work , what do you have to loose but a few hours of time if it doesn't work . Plus you might enjoy it . So if it doesn't work your buying a fender , if you don't try your buying a fender.
85 D110 3.5 3 DR
Old February 5th, 2014, 07:23 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
buy new and sell the old unit here
I have replace B with rivets.
good luck with your search
Old February 5th, 2014, 07:50 PM
Neil McCauley
Neil McCauley
I saw this article on LRO where you sand all the paint off first. Than take a sharpie marker and draw lines over the dents. Than you use a torch to heat it up til the marks you drew start to fade or dragging a scrap piece of wood over the heated surface leaves a dark mark. Supposedly it is now annealed and ready for the plastic mallet treatment. Your suppost to use a dolly on the opposite side of the hammering like the sand bag or a appropriately shaped mallet.
Robert Deniro
Old February 5th, 2014, 08:13 PM
Someone posted a link to a video here once of a guy doing an amazing piece of work on a porch or something. Took a dent and crease out that you wouldn't believe without any filler.
Originally Posted by pendy
I'm here for the D's
Old February 5th, 2014, 09:18 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Yea I think it was a guy fixing a cobra rear quarter panel
85 D110 3.5 3 DR
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Amazing body repair.
You can anneal with the torch. I tried some rudimentary repair on flat panels with decent success based on his methods
ID:	89220   Click image for larger version
Old February 5th, 2014, 09:23 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Jpayne looks like we where thinking the same thing at 5:18 :-)
Nice work on that quarter .
85 D110 3.5 3 DR
Old February 5th, 2014, 10:05 PM
Nice work Jeff! I plan to give that a go once I get to the bodywork stage of my project.
Old February 5th, 2014, 10:13 PM
Bill Larson
Bill Larson
Jeff, that's like magic! Very cool video.
body
Repair/ Body Shop for Defender90 Sam401 Defender Technical Discussions 3 November 21st, 2013 10:23 AM
Body Shop/Rover Repair Needed chrisconnie Defender Technical Discussions 8 November 8th, 2009 11:57 AM
hail damage/ body repair CaptMidnite Defender Technical Discussions 2 January 18th, 2007 03:30 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
