body panel replacement - Defender Source
Old January 18th, 2009, 11:06 AM
andyrad
Andy Radlgruber
None.
I just bought two new rear wings for my NAS D-90 from Safari Rovers off of ebay. My drivers side has a large dent from a rear ender before I owned it and the passenger side some corrosion beginning so I thought I would just buy new. The price was right regardless.
My question is has any one ever removed a rear wing before? Do these need to be spot welded in place?
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old January 18th, 2009, 11:31 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You can replace them by drilling out the spot welds, but you will not find a spot welder able to spot weld the aluminum. You can use countersunk rivets and put a little bondo or lead over the rivets and make it look like its spot welded or you can TIG weld it to look like a spot weld. Now that's the spot welds, the rest is riveted in place - a pneumatic rivet gun is essential
ac, body
Gas cap pulled away from body panel Krna Defender Technical Discussions 9 November 12th, 2009 01:13 PM
Replacement of Land Rover D90 rear left panel. seriesgarage Defender Technical Discussions 4 July 14th, 2009 10:57 PM
Body Panel Extravaganza madcowdungbeetle For Sale - Parts 12 November 30th, 2008 10:55 AM
Body Panel Removal Epsom_D2 Defender Technical Discussions 4 June 13th, 2008 01:56 PM
Body Panel Gaskets Grover Defender Technical Discussions 1 April 30th, 2006 10:29 PM
