Body-Off Time Estimate - Defender Source
Old January 23rd, 2018, 08:54 PM
MiamiDefender
Christian
1991 Defender 110
Day 1 of body-separation is in two weeks and I just wanted to get some input from those that have done a 110 before. How long did it take you to separate the body from the frame in terms of unscrewing, un-harnessing, unhooking, etc.? Is it unreasonable to think it could be done in something like 8 hours?
Old January 23rd, 2018, 09:00 PM
Naplm00
Matthew
On an early truck with no major rust could probably be done in an hour or two by someone who has done one before.
Having ac/fan shroud/tons of electric add ons will just add time.
Old January 23rd, 2018, 09:01 PM
if you have done it before and lifting the body as one piece, yes.
Typically if doing this its because the chassis is rotten and that usually means everything is crusty and often means all the bolts have to be cut
Old January 23rd, 2018, 09:50 PM
Jmalpass
Jack M
Defender
I did it myself (other than the physical lift itself) in about 12 hours with no previous experience. That included cutting off aforementioned crusty hell bolts. I was a little crude with some bits that were going to the bin though to save time. I pulled the doors off to make life easier to lift it all off.
Old January 23rd, 2018, 10:00 PM
MiamiDefender
Christian
1991 Defender 110
Makes sense, thanks all!
body
time estimate to do cappings. jack SF Defender Technical Discussions 3 May 7th, 2011 03:55 PM
Time Question GYM Support & Suggestions 7 March 1st, 2008 10:36 AM
110 3door rear body forsale headdamage For Sale - Parts 4 August 4th, 2005 03:19 PM
Inconsistent post time bd90 Support & Suggestions 4 December 19th, 2003 08:34 AM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
