Body Damage - Defender Source
Old June 19th, 2007, 11:29 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Body Damage
Long story short, pulled out a jeep which its accelerator stuck in the process. I searched around and basically it isn't looking good to beat this back out I assume. Can you just replace the panel and the cap without taking the tub out? What do you guys think would be the easiest course of action. If i can beat it out to look half decent I would just do that. It was a friend that hit me so it may be hard to get him to fork out enough dough.
ID:	9658   Click image for larger version
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 19th, 2007, 11:40 AM
Have him hit the other side so they match...
Old June 19th, 2007, 11:46 AM
Grover's Avatar
Grover
Unhappy
Ouch! Sorry that happened. Yeah, it would be tough to make a friend cough up the $$$ to fix it. I'm no body expert but it looks like a clean yet sharp bend that might be tough to beat out, i.e. the aluminum may split at the crease. To replace the skin, you would have to drill out all the spot welds and rivets and remove the capping. Call George @ RDS, he may have some panels.
Good luck!
Cheers...
Old June 19th, 2007, 02:09 PM
Bang it out. It will add character.
Old June 19th, 2007, 03:25 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If you decide to beat it out, heat it first. Liquid dish washer soap on one side and torch on the other. When the soap bubbles and turns black - stop heating. The aluminum can now be "beat on" without cracking it. The crease corresponds to the wheel well and beating it out will be difficult. It will look nicer to drill out and replace.
Old June 19th, 2007, 03:35 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
How about a flush patch ...
You could always cut out what is bent very neatly and then, using countersunk rivets make a flush patch. The seam would show but no one ever looks at both sides of your car at the same time.
Just an idea ! It is used extensively in aviation.
Pat
Kirk Lazarus, Tropic Thunder
Old June 19th, 2007, 03:45 PM
Monkeyboy
Guest
Posts: n/a
Screw that - he does carry insurance, right?
Call the agent and get it fixed right. I wouldn't make a friend eat the deductible, but heck let the ins co pay for most of it.
Old June 19th, 2007, 03:58 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I actually thought it was a cooling vent for the rear brake system? I am with Keith, you guys split the deductable and let insurance take care of it properly.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old June 19th, 2007, 06:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
When I made my 90, all my panels were used. I did all the body work and all the painting. The problem with what you are facing is that the panel most likely is stretched, especially at the horizontal line of rivits, and fixing it will be very difficult. You won't be able to bang that out completely. Matter of fact, I think it may be difficult to get it even close enough that the aluminum "bondo" will be thin enough to really work well. If it were mine, I would just get some aluminum sheeting or a replacement panel and skin that area, preferably from the back, and then use the aluminum bondo to skim it back to flush. I would probably first try and bang it out using heat described above and see how close I could make it and if I could get within about 1/4 to 3/8" I would fill it with the aluminum fill. Removing that panel to replace it would be a major undertaking.
Actually, as I give it more thought, I would get a replacement side, and cut out just the area that is dented from both the truck and the new panel but leave about 1" of the dented panel below the horizontal line of rivits. I would drill out all the vertical rivits. I would cut a 2" strip of aluminum and bond it (or rivit it) to the 1" horizontal flap you left on the truck and then put then bond that to the new panel as it lines up. Kind of like using tape behind the two lined up panels. This little seam I would fill in with aluminum fill and have it painted.
Good luck
Old June 19th, 2007, 07:14 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
What makes it harder to just bang out is the corner was pushed in a little bit. You can see the capping is not straight down. My bumper took most of the hit, but just enough caught the corner. Light guard saved the light, but I am sure it didn't help my body panel.
1995 Defender ST
1996 Discovery SE7
Old June 19th, 2007, 07:28 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Go to an Audi dealer and ask for a good body shop that does aluminum, the A8 is aluminum and they will have a source that knows how to fix it.
Old June 19th, 2007, 07:41 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thats a no-brainer!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 19th, 2007, 07:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Good luck!
Cheers...
I have done this and this is the only way to make it look nice and stock. Replace the panel. Its not that hard. I just did a series tub an dit came out really nice. If you lived in the area, I would have done it.. lol
Legend in My Own Mind.
Old June 19th, 2007, 08:03 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You can use a compound called Speedgrip Structural Adhesive. Need about 3/4" to 1" overlap for it to work, but you could get (or fabricate) a rear corner. Cut away the section about an inch below the rivets. Carefully bend that lip out to near vertical and bond the replacement section to that lip. New corner cap and a small amount of bondo for the seam created and new paint.
You can also use a backing piece of aluminum and lay the upper and lower pieces edge to edge - but then you would have to drill out the rivets above the bend to get a flat surface to bond to the backing piece.
Old June 20th, 2007, 08:43 AM
btate
Bryan Tate
d90
I have guy here (in Wilmington) that could weld a tin can back together.......
I punched a hole in the side of my 110 and he fixed it perfectly.
He restores porsches/jags/muscle cars
Email me for his info.....
Old June 20th, 2007, 09:17 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Get it fixed right or you will regret not having it done. Now is the time while your friend is around and owns up to the accident. And by the way, if he truly is a friend, he won't avoid helping you get some resolution to this. This is beyond a blemish and will hurt should you ever sell.
"Uhh...I think they all leak like that."
Old June 20th, 2007, 06:27 PM
61rover's Avatar
61rover
John Crouse
Body Panel
George has that body panel (new) on sale for $50. Give Rovers Down South a call.
Old June 20th, 2007, 06:36 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Thats a no-brainer!
LOL!
Ah yes. The sawzall. The perfect band-aid.
Old June 20th, 2007, 11:40 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
Thumbs up
Thats a no-brainer!
haha i like it
Old June 23rd, 2007, 12:37 AM
I did that exact bit of damage at Uwharrie this year - it does not go back into shape well at all. That being said, I plan on just rolling with it for a couple years. Maybe I just badly need the cred...
body, damage
hail damage/ body repair CaptMidnite Defender Technical Discussions 2 January 18th, 2007 03:30 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
