Body Damage - Page 2 - Defender Source
Old June 24th, 2007, 09:04 PM
94SW,4.6HSE,93LWB,83 110
This panel is easily replaced. I have virtually re-bodied most of my defender (bought someone elses rollover). It's easiest to buy the complete side of the truck to include the side and rear panels as well as a new wheel well. This way you simply drill out the rivets in the cappings and the ones under the floormat that hold it to the rest of the tub. Driver's side is easier than the passenger side due to the gas filler. I paid $800 a couple of months ago for the entire side of the truck less the cappings. I then riveted it back together with rover rivets. You can improve on the original by doing things like galvinizing the cappings and placing plastic between the steel cappings and aluminum panels to isolate them from galvanic corrosion. Do it once and do it right.
body, damage
hail damage/ body repair CaptMidnite Defender Technical Discussions 2 January 18th, 2007 03:30 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
