Body cappings (one for the restorers/rebuilders) - Defender Source
Old February 20th, 2008, 08:01 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Question Body cappings (one for the restorers/rebuilders)
Few may know I stripped the Cube a tad in order to slightly restore her for the times to come...
Body cappings were showing little rust in a couple of points,the Series-style doors had the galvanized cappings while the tub was factory white,plus I always wanted the vintage,long lasting galvanized look.
So the Cube looks like this since a couple of weeks (attached pic)
Then I made my usual big mistake and had the cappings sandblasted and galvanized
(always thought it's a quick cheap job).
I don't know the actual Ä price for new,original,galvanized cappings but I'm now quite sure with the money I spent so far I could have allowed several sets
Other great new the cappings came back "slightly" bent
At the moment I'm stuck here
(second attachment as sample);
the center capping on the bulkhead is a PITA to refit and,once done,the holes don't match anymore with the smaller cappings hidden in corners (I hope it makes sense so far).
The center capping look a tad curved now,I can align all the holes one side but it shifts to the other and I can't place a single rivet anymore.
I tried to rivet it down from the center section in order to spread it levelled but no avail.
Does galvanizing stretch body cappings?
Or did the Cube shrinked while waiting in a cold box?
Do I miss something here?
Dumb question maybe but I don't really want to turn the exiting holes into craters
nor I can't hammer the poor creature to bits (although I went close yesterday)...
(sigh)
ID:	12231   Click image for larger version
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 20th, 2008, 08:17 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Galvanizing warps thin parts. When I'm fitting cappings, I use 3/16" cleco clamps and when it is all aligned and set - I take one cleco at a time and exchange it for a pop rivet. For the bent and warped cappings, I would straighten them off the tub - not use the tub to try and hold them straight.
Old February 20th, 2008, 09:41 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Cleco
Thanks Chris.
I don't think those "Cleco" clamps are available at the local shop but will do a search for something similar.
I will drill the rivets out and try the clamp approach.
Michele
D90 VNTdi
[O]===[O]
Old February 20th, 2008, 10:16 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I experienced similar issues when I restored a '64 5 door 109. I had to slightly cold set (bend) some of the longer cappings to get them to align with existing holes in the tub. Use a block of wood between your hammer and the freshly gavanized capping so you don't dammage it. I then placed every rivet in the appropriate hole before I started "popping" them. Depending on how clean the galvanizing is you will likely have to clean out extra gavanizing from the capping holes with appropriately sized drill/drill bit. And yes you did the appropriate process of using your existing cappings. If you had bought new galvanzied cappings the hole patterns would not match well with the holes in the tub.
Old February 20th, 2008, 10:29 AM
Cube II's Avatar
Cube II
Michele
1997 D90
My biggest fear exactly
keeping the original parts instead is only giving me half the trouble now
Gotta fix this stuff,hopefully with some "finesse"!
Michele
D90 VNTdi
[O]===[O]
body, rebuild
Brand New Body Cappings For Sale! Stmpede For Sale - Parts 2 May 23rd, 2007 10:37 AM
Body cappings for tail of truck evilfij Wanted 4 March 10th, 2007 06:09 PM
Body cappings & galvanization thewap Defender Technical Discussions 15 July 12th, 2006 11:02 AM
Where to find galvanized body cappings? Seanh Defender Technical Discussions 5 March 29th, 2006 04:48 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
