Body capping question - Defender Source
Old June 18th, 2012, 01:07 AM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
After just about a year of sitting on them I've finally gotten the time to paint the replacemet body cappings I've got for my ROW 90 HT. I've read through several posts but am coming up short on detail around seals, if any, in this process. As far as I can tell there are seals between the cappings and the side/window panels (I've got PN 333487 from AllMakes4X4)... in other words, these appear to go on TOP of the cappings. Are there seals of any kind that go BELOW the cappings, on top of the tub? Use panel adhesive??
Many thanks!
-Gardner
Old June 18th, 2012, 02:47 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
There is usually a sticky foam type of seal between the lip (on the top of the bodywork) and the bottom of the capping.
I can't find it on microcat, but whenever i've refitted them, I just use a bead of body panel sealer, like tigerseal or similar.(that said, you'll never get them off again... the factory sticky pads are hard enough to remove!)
Old June 18th, 2012, 09:57 AM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
Cappings
Thanks Jamie!
Old June 19th, 2012, 04:26 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
cappings
I'm gonna try 3M 4000.
body
Replace body capping Skeena river rover Defender Technical Discussions 10 December 9th, 2011 12:54 PM
Fitting D110 Body Capping mattarm Defender Technical Discussions 9 July 19th, 2010 07:43 PM
Body Work Question CDN90 Defender Technical Discussions 27 October 7th, 2009 09:32 AM
What are the body capping options / differences? Hans Defender Technical Discussions 4 August 9th, 2009 12:49 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
