body capping on rear tub - Defender Source
Old October 6th, 2004, 09:44 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Has anyone replaced the body capping along the top of the rear tub, just rivets or is it welded on(I haven't looked closely at it yet)?. Any leads on best places to get capping kits(I'll check with RDS,ect) would be appreciated as well. Thanks for the help.
Tis
Old October 6th, 2004, 10:03 AM
They are not welded on, I read an article in LRM or LRO last year and they replaced the capping's and it seemed real easy, I think you just drill out the rivets holing it on. The mag recommended replacing it with Galvanized capping. I think the hard part on a NAs 90 is dealing with the Roll Cage.
Old October 6th, 2004, 11:04 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I replaced mine when the pickup top was installed. It was just a matter of removing the cage and the rivets.
Make sure you use the proper rivets when you install the new one, they are kind of an odd size and I used some standard ones that looked close but they ended up rattling and not fitting proper so I had to drill and replace them.
Old October 6th, 2004, 11:23 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Did you do anything to isolate the galvy capping from the aluminum? Seems you would get the classic galvanic reaction over time. right?
Old October 6th, 2004, 03:20 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The same factory weather stripping stuff that was installed when it was new.
Old October 6th, 2004, 06:10 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
On my truck there was no sealant between the capping and body. Some got sealant, some didn't. All you really need to do is put a good coat of paint on the body where the capping covers, and the back of the capping.
How in the world have I spent this much money and still don't have a running vehicle?
body
rear 110 body capping WhiteD90 Wanted 10 May 6th, 2008 11:25 AM
110 3door rear body forsale headdamage For Sale - Parts 4 August 4th, 2005 03:19 PM
D-90 Rear Tub Needed ember Wanted 12 March 10th, 2005 05:08 PM
Galvanised tub capping jabber Defender Technical Discussions 9 March 3rd, 2005 09:35 PM
