Body bushings - poly or factor rubber?? - Defender Source
Old January 17th, 2005, 08:17 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I was thinking about replacing my body/suspension bushings and I had assumed I would just go with polyurethane, but then I spoke to someone who was dead against them as they 'squeak' alot after a little bit of time, and he feels that the factory LR bushings are good enough.
What say you? Anyone out there with squeaky poly bushings??
Old January 17th, 2005, 08:35 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I had iron man poly's for about 30k(the complete kit)on my stock 90(wife's car) with hardly any off road use.The 90 started to feel lose, I thought it needed a shims adjustment.The shop checked the 90 and stated the problem was the bushing in the radius arms. I went to the dealer to check for myself,the bushings had disintergrated on the inside.All the bushing were replaced back to OEM rubber and the 90 rides tight and smooth, more like a passenger car.
Old January 17th, 2005, 09:16 PM
artm
Arthur Maravelis
97 SW
I agree with Jorge. The rubber takes up any slack while the poly doesn't. After one try with poly I've gone back to rubber for the S3 and the D90.
Old January 17th, 2005, 09:55 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
There was a discussion about this not too long ago, the general consensus was that OEM was the way to go.
http://www.defendersource.com/forum/...ead.php?t=2252
Old January 18th, 2005, 03:10 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Thanks guys! I'll go with the OEM after reading these threads.
Old January 20th, 2005, 01:13 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm just about to rebush wiyh OEM rubber.
Once saw a trailing arm shear at the chassis end 'cause the poly bush didn't have enough give
Also the poly bush material will wear away the steel where it rubs, rubber won't
Mike Hammond
Old January 24th, 2005, 10:12 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Definitely OEM
Old January 26th, 2005, 05:08 PM
mikeslandrover
Mike Hammond
Mind you, the bushes on the front axle are absolutely shredded
I take 2 lanes just to drive straight. Wandering is just too small a word for it at the moment
Mike Hammond
Old February 7th, 2005, 01:47 PM
mikeslandrover
Mike Hammond
I think I got my moneys worth out of these suspension bushes!
It was to say the least rather difficult to keep the Land Rover on track - it wandered all over the place on the road.
Name:	worn bushes.JPG
Mike Hammond
Old February 7th, 2005, 01:48 PM
Yeah but I bet it flexed good!
Old February 7th, 2005, 02:12 PM
mikeslandrover
Mike Hammond
It was bril offroad. 28" of corner to corner movement. ie 1 wheel 28"in the air with the other 3 on the ground.
Clay with flints is the ground type where I do most of my offroading and the flint tears tyres and stuff to shreds.
Mike Hammond
Old February 7th, 2005, 03:47 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I am just finishing up replacing the bushings on my truck today. Go OEM. Have access to a 20 ton press. I burned the rubber out and cut the outside sleeve with a sawzall then had to chisel out the sleeve on my front bushings. I got smart and used my dad's press for the rear bushings. Next job are the front bearings.
Old February 10th, 2005, 02:00 PM
mikeslandrover
Mike Hammond
12 ton fly press shifted the bushes in the photo no trouble. i'd put copper grease on them when they went in and they just glided out and the new ones just slipped in with more copper grease. Need to make sure they go in square though!
Mike Hammond
Old February 10th, 2005, 03:12 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Anyone use the OME caster corrected bushes!? Are they a pain?
Peter
Old February 10th, 2005, 05:59 PM
mikeslandrover
Mike Hammond
Isuppose you'd have to get the orientation correct
Mike Hammond
Old February 10th, 2005, 06:42 PM
I havent read many good things about the OME castor correcting bushings FWIW
ac, body, bushings, rubber
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
