Body alignment questions - Defender Source
Old August 27th, 2011, 12:10 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I have my bulkhead and tub sitting on the frame and I am getting ready to start aligning it and wanted to ask / confirm a few items prior to moving forward.
1. Jim C posted that the frame should be level and that the bulkhead should be perpendicular to the frame (frame 0 degrees bulkhead 90). Where is the best location to measure for level on the frame. I am currently measuring on the flat part located on the top of the frame as shown in the attached picture.
2. I am planning to use the string trick as described by Jim C in the following thread, any other tips / recommendations before I start?
http://www.defendersource.com/forum/...3&postcount=45
3. What is the typical door gap on a 90? 1/4 3/8 1/2
Dave
Old August 27th, 2011, 01:16 PM
Dave, I am no expert and in fact may be a complete hack and/or not know what I am doing I'm told.
But a quick survey of two NAS 90's and a series says 1/4 to 3/8 gap or whatever looks best to you. Maybe make the rer gap consistent with the hinge side, and just keep it the same amount top and bottom?
Originally Posted by pendy
I'm here for the D's
Old August 27th, 2011, 02:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Stick the doors on and see how it looks, that's what I did, panned out alright in the end, maybe I was lucky. The mix was replacement chassis, galvanised bulkhead, original doors and sills & second row doors from other trucks. It all looked a bit wonky until I put the roof on, that pulled everything into shape.
Mike Hammond
Old August 27th, 2011, 05:23 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, for a 2-door/regular I bolt things loosely, include the doors with everything loose, get them in place and tighten them up. Most everything, except the bulkhead, can be easily loosened later for further adjustment. The bulkhead can be as well, just not as easily.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 27th, 2011, 06:11 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
what he says
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
alignment, body
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Body Panels and Work- Atlanta gtg067i Defender Technical Discussions 1 February 14th, 2005 05:03 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
