Blue smoke on my Diesel - Defender Source
Old June 17th, 2010, 01:00 PM
This week, I started to get blue smoke out of my 2.8 TGV. It occurs intermittently while it's relatively cold, and only at idle (after about 15-20 sec) , or starting to move from a stop (big ploom). it doesn't always do it.
This engine proably is still under 30k, and didn't smoke ever until this week. Some things that have changed on it are:
  1. increased donaldson pre-cleaner on snorkel from 7" to 10" due to realization that 7" was way to small for this engine.
  2. drove at highway speeds last week running at 215F for 2 x 2hr stretches. Turns out that 2 months ago, when I completed my Webasto install, I did a horrible job at bleeding the coolant, and was 2 gals short (of a 5 gal sys). Now it is running at 200F on highway, and under 180 around town.
  3. Axles, tranny, T-case and fuel tank all plumbed into extended breather manifold.
I know that blue smoke tends to indicate oil in the combustion, but I'm uncertain how to begin the inspection/process of elimination on this.
I'm going to completely top off tonight and begin monitoring coolant and oil consumption, but does anyone have any further insight?
Old June 17th, 2010, 02:15 PM
No.... That is for petrol engines. Engine oil will burn as cleanly as diesel.
Check the timing and air filter first. Cold start smoke is usually one or two cylinders not burning. The smoke is partially burnt fuel. This can be due to low compression, retarded timing, bad spray pattern....
You could also have a turbo seal gone leaking into the turbine, but I doubt it.
Old June 17th, 2010, 06:31 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Unhook the snorkel tubing just to be sure the precleaner is not choking the motor. easy check...
When is the last time you changed you fuel filter? Bad fuel? is is stumbling at all?
Other than that, I'd check the timing.
Old June 17th, 2010, 06:54 PM
fuel filters just changed, both are racor separator filters.
Does anyone know if the 2.8 TGV uses the same timing tools as a 300 TDI?
Old June 17th, 2010, 08:59 PM
rovertrader's Avatar
rovertrader
Dale
sent you a pm, but have the International guys take a look/see...
diesel
Blue Smoke While Under Compression outfield Defender Technical Discussions 7 April 3rd, 2010 03:13 AM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
tdi blue smoke D90user Defender Technical Discussions 11 November 15th, 2007 11:07 AM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
