blue smoke, need help on where to start, - Defender Source
Old February 9th, 2015, 08:32 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Here's the deal, when running at normal temperature all is well, good power, mpg is 23 to 25, a puff of black smoke at start up and a little black smoke when accelerating, park for the night or long enough for engine to cool down and it will blow blue smoke for about 5 minutes when started. Ideas? 300 tdi, l had the head gasket replaced and the head redone, turbo rebuild at the same time.
Old February 9th, 2015, 08:55 AM
could be a bunch of things. turbo, valve seals, clogged oil seperator. don't ignore it, or it will sneak up and surprise you down the road. compression test will rule head gasket in or out. I just had my turbo rebuilt, and they were able to isolate it by pulling the turbo off the manifold and seeing if the exhaust manifold had oil deposits in it. they said if oil is in the manifold then it's block related, if not, then it's turbo. a good diesel shop can isolate it. you have several good shops on this forum right there in florida to take it too for diagnostics.
Mark Kellgren
KM4BOR
Old February 9th, 2015, 09:00 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Worn valve guides or bad seals that allow oil to seep into the cylinders through the valve guides.
Cracked head allowing oil to seep into a cylinder.
When the engine heats up the crack closes and seals off.
These are long shots.
Could the blue smoke be from over fueling?
You could have an injector that leaks down and dumps fuel into the cylinder when cold.
Then when it is running, the injector dump is not noticed, but it leaks down when the engine cools and sits a while.
I think this theory is more likely that the valve guide/cracked head, but is still pretty rare.
RDavisinVA
Old February 9th, 2015, 09:10 AM
find a bosch shop and have them test your injectors. my local one will do it for $10 per injector.
Mark Kellgren
KM4BOR
Old February 9th, 2015, 09:30 AM
Id go with valve guide seals if its blue smoke on start up. Older seals tend to pop off the end/top of the valves stem. Once that happens it just rides up and down on the valve and offers no seal @ all. You have to pull head and use a valve spring compressor to access the bastids. If its only an issue on start up I think I'd live with it.
Old February 9th, 2015, 08:24 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I 2ed doing a compression check
Old February 9th, 2015, 09:27 PM
CavemanDiesel
Eric Smirh
1985 D90
Thanks for all the replys, I've been putting off a trip to Sharfi HP, I'm going to call Steven tomorrow. Road trip I see a new head liner in my future and he will sort the blue smoke problem,
white smoke...yup electrical short, need help please!! El Solis Defender Technical Discussions 0 January 20th, 2014 12:48 AM
Blue smoke on my Diesel Overlander Defender Technical Discussions 4 June 17th, 2010 08:59 PM
Blue Smoke While Under Compression outfield Defender Technical Discussions 7 April 3rd, 2010 03:13 AM
200tdi need help with bluish smoke snowkistdynasty Defender Technical Discussions 14 March 26th, 2010 01:43 AM
tdi blue smoke D90user Defender Technical Discussions 11 November 15th, 2007 11:07 AM
